I downloaded and extract the files.
I right click on the .nf file but there is no option for Install. In the past I have set up so that .inf is opened with a notpad by default so that may be the problem but I don't know how to undo this.
Hi,either drop it into the system folder under windows or put the dll file into the program you are using.
Cannot install lame mp3 on vista x64
By jarko in forum AudioReplies: 14Last Post: 28th Apr 2010, 03:12 -
AC3 ACM Will Not Install with Vista 64
By Mitchum22 in forum AudioReplies: 4Last Post: 19th Aug 2009, 09:15 -
lame mp3 doesn't show up in vbubMOD after install
By uk_dan2k in forum Video ConversionReplies: 10Last Post: 19th Sep 2008, 18:07 -
Vegas + LAME ACM = just a myth..?
By Gew in forum EditingReplies: 3Last Post: 24th Jul 2008, 02:48 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43
