Results 1 to 10 of 10
    Feb 2008
    I've used SVCD2DVD V2 for some time now and it's a great product. I recently upgrade to V2.5.3600 (latest version) and have found a problem:
    When I use the "Encode video to audio duration" option in the "Menu"/"Audio Encoding" settings, the resulting menu has a jitter/noise/aliasing. It's as if the menu has two slightly different frames which it is constantly switching between. This can be seen both on the PC and on my Sony DVD player. I tried several different images for the background.
    I know, in general, that I shouldn't need the "Encode video to audio duration" option but I have found that without it, my Sony DVD player just plays approx <1 second of the menu, although the DVD plays fine on my PC. I always used this option in V2 with no problems.
    I think I've tried about every different option available under the settings, my only choice for the time being is to have no audio.
  2. I hate to ask the simple questions of a long time user, but:
    Are you using the correct standard (PAL, NTSC) for your location?
    Does the standard used match the standard of the assets used in your project?
    What is the resolution of your source background image?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Feb 2008
    Thanks for the response Jikchung.
    I've tried both PAL and NTSC menu, and tried with both PAL and NTSC assets. I've never had a problem with mixed menu/assets standard on my DVD player, here in the UK.
    One image is 1024 x 768 and another (one I've used on many DVD's under SVCD2DVD V2 with no problem) is 720 x 540.
    I'm going to try and achieve what I want using SVCD2DVD V2, rather than V2.5, using all the same assets, background, audio, and settings, and see what the result is.
  4. Another question is whether you have tried a disc displaying this problem on a different player?
    Dwight
    - Herm Albright
    Feb 2008
    I only have one conventional DVD player (the Sony) which exhibits this behaviour. But both my main PC and my laptop show the same abnormality when the DVD is played on them.
    I checked the .VOB file for the menu itself and that shows the same problem, so it seems to be a problem with the menu generation/encoding, rather than the playback.
  6. Cool, that's what we needed to know. Can you post a log file (under the help button) for a run that did this? Hopefully ChrissyBoy will have some time to have a look into it.
    Dwight
    - Herm Albright
    Feb 2008
    I tried it with SVCD2DVD V2, same assets, same menu background, same menu audio, same options and everything is OK, so 100% sure it is a V2.5 issue.
    Here is the log from V2.5.3600, as requested:
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.5
    Version: 2.5.3600.0
    Executable: J:\SVCD2DVD v25\SVCD2DVD.exe
    Executable size: 2.57 MB
    Executable size in bytes: 2703443
    Executable CreationTime: 09/12/2007 17:41:26
    Executable LastWriteTime: 06/02/2008 11:02:23
    Executable LastAccessTime: 08/02/2008 12:38:15
    ************************* Operating System *************************
    Operating System: Microsoft Windows 2000 Server
    Service Pack: Service Pack 4
    Version : 5.0.2195
    Windows Directory : C:\WINNT
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 1
    Local: 0409
    Total Physical Memory: 511 MB
    Free Physical Memory: 18.5 MB
    Total Virtual Memory: 1.71 GB
    Free Virtual Memory: 358 MB
    ***************************** Computer *****************************
    Computer Manufacturer Name: VIA Technologies, Inc.
    Computer Model: VT8363
    System Type: X86-based PC
    Computer Name: HOME-SERVER
    DomainRole: xd1f84ac4911c6b77
    Number Of Processors: 1
    User Name: HOME\administrator
    ***************************** Processor ****************************
    Manufacturer: AuthenticAMD
    Processor: AMD Athlon(tm) Processor
    Description: x86 Family 6 Model 4 Stepping 2
    CPU Speed: 1.33GHz
    CPU FSB: 133MHz
    L2 Cache Size: 256 bytes
    ***************************** Time Zone ****************************
    Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
    ****************************** VIDEO *******************************
    Name: LogMeIn Mirror Driver
    Processor:
    Mode:
    Video Ram: 0
    Status: OK
    Processor: RADEON 7200 Series AGP (0x5144)
    Mode: 1280 x 1024 x 4294967296 colors
    Video Ram: 32.0 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 1.53 GB
    DeviceID: D:
    FileSystem: NTFS
    FreeSpace: 19.7 GB
    DeviceID: F:
    FileSystem: NTFS
    FreeSpace: 37.7 GB
    DeviceID: G:
    FileSystem: NTFS
    FreeSpace: 4.56 GB
    DeviceID: J:
    FileSystem: NTFS
    FreeSpace: 5.87 GB
    DeviceID: L:
    FileSystem: NTFS
    FreeSpace: 6.92 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ************************* ProjectMetaData **************************
    <?xml version="1.0" encoding="utf-8"?>
    <SVCD2DVD DateTime="08/02/2008 12:41:27" Filename="NONE">
    <AssetSet>
    <Asset ID="22011782-2523-4366-afd8-785430238bc8" Path="D:\Lost\Season 4" Filename="lost.s04e00.past.present.and.future.real .repack.hdtv.xvid-xor.avi" />
    </AssetSet>
    <DVDStructure>
    <TitleSet Name="LOST 4-00" PostCmd="" MenuButtonType="0">
    <MenuButton X1="312" Y1="66" X2="649" Y2="103" FontFamily="Arial" FontSize="20.25" FontStyle="1">Past, Present and Future</MenuButton>
    <Title Name="lost.s04e00.past.present.and.future.real.rep ack.hdtv.xvid-xor.avi" AssetID="22011782-2523-4366-afd8-785430238bc8" MplexOffset="0" />
    </TitleSet>
    <DVDMenu Normal="-1" Highlight="-8323200" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="D:\Lost\LOST.bmp" AudioPath="D:\Lost\36 LOST (End Title).mp3" />
    </DVDStructure>
    <Settings>
    <General InitialAssetFolder="D:\" InitialDVDFolder="D:\SVCD2DVD DVD Output" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="D:\SVCD2DVD Projects" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" />
    <Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Arial" FontSize="20.25" FontStyle="1" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="True" MenuAspectRatio="AR_4_3" />
    <Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="False" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
    <Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
    <Burning BurningMethod="ImgBurn 2+" ImgBurnPath="J:\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="True" DVDDDontBurn="False" />
    </Settings>
    </SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    File Size: 349 MB
    file=D:\\Lost\\Season 4\\lost.s04e00.past.present.and.future.real.repack .hdtv.xvid-xor.avi
    FormatName=avi
    Num_Frames=58254
    DurationInSecs=2429
    Duration=00:40:29.6
    VideoCodec=mpeg4
    VideoFFSTNum=0
    Width=624
    Height=352
    Standard=NTSC (Film)
    BitRate=1208
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1StreamID=[0x1]
    Audio1SampleRate=48000
    Audio1Codec=mp3
    Audio1BitRate=128
    Audio1Channels=2
    AVI2MPG: 9000kbs Full-D1
    12:41:27: Looking for AVI PAR...
    Pass 1/1: Processing lost.s04e00.past.present.and.future.real.repack.hd tv.xvid-xor.avi
    12:41:30: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
    12:41:30: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
    12:41:30: libavutil version: 49.1.0
    12:41:30: libavcodec version: 51.27.0
    12:41:30: libavformat version: 51.12.1
    12:41:30: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
    12:41:30: Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (23976024/1000000)
    12:41:30: Input #0, avi, from 'D:\Lost\Season 4\lost.s04e00.past.present.and.future.real.repack. hdtv.xvid-xor.avi':
    12:41:30: Duration: 00:40:29.6, start: 0.000000, bitrate: 1208 kb/s
    12:41:30: Stream #0.0: Video: mpeg4, yuv420p, 624x352, 23.98 fps(r)
    12:41:30: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
    12:41:30: Output #0, dvd, to 'D:\Lost\Season 4\lost.s04e00.past.present.and.future.real.repack. hdtv.xvid-xor_S2D.mpg':
    12:41:30: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 9000 kb/s, 23.98 fps(c)
    12:41:30: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    12:41:30: Stream mapping:
    12:41:30: Stream #0.0 -> #0.0
    12:41:30: Stream #0.1 -> #0.1
    12:41:30: Press [q] to stop encoding
    14:00:59: video:1727872kB audio:66436kB global headers:0kB muxing overhead 1.982707%
    14:01:00: Using pulldown.
    14:01:03: AVI2MPG: done.
    14:01:05: Done: Processing assets for DVD creation
    Authoring DVD Folders
    14:01:07: Creating TitleSet # 1
    14:01:08: SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    14:01:08: -->: DVDFolders creating VTS
    14:01:08: -->: VTS 01
    14:01:08:
    DVD Folders: Processing J:\SVCD2DVD v25\dummymenuNTSC.mpg...
    14:01:08:
    DVD Folders: Processing D:\Lost\Season 4\lost.s04e00.past.present.and.future.real.repack. hdtv.xvid-xor_S2D.mpg...
    14:05:15:
    14:05:15:
    14:06:14:
    14:06:14: Finalising DVD...
    14:06:14: Encoding menu...
    ---------------------------- ENCODING MENU ----------------------------
    TV Standard: NTSC
    Aspect Ratio: 4:3
    Image size: 720x540
    Resize size: 720x480
    14:06:24: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
    14:06:24: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
    14:06:24: libavutil version: 49.1.0
    14:06:24: libavcodec version: 51.27.0
    14:06:24: libavformat version: 51.12.1
    14:06:24: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
    14:06:24: Input #0, mp3, from 'D:\\Lost\\36 LOST (End Title).mp3':
    14:06:24: Duration: 00:00:29.3, start: 0.000000, bitrate: 191 kb/s
    14:06:24: Output #0, mp2, to 'C:\\Documents and Settings\\Administrator\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.3600.0\\menu\\menu.mp2':
    14:06:24: Stream #0.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    14:06:24: Stream mapping:
    14:06:24: Stream #0.0 -> #0.0
    14:06:24: Press [q] to stop encoding
    14:06:24: bits_left=1202
    14:06:24: bits_left=1100
    14:06:24: bits_left=1282
    14:06:24: bits_left=1241
    14:06:24: bits_left=1361
    14:06:24: bits_left=1340
    14:06:24: bits_left=1234
    14:06:24: bits_left=1148
    14:06:24: bits_left=1033
    14:06:24: bits_left=1353
    14:06:24: bits_left=1291
    14:06:24: bits_left=1233
    14:06:24: size= 195kB time=7.1 bitrate= 224.0kbits/s
    14:06:25: size= 383kB time=14.0 bitrate= 224.0kbits/s
    14:06:25: size= 559kB time=20.4 bitrate= 224.0kbits/s
    14:06:25: size= 754kB time=27.6 bitrate= 224.0kbits/s
    14:06:25: bits_left=680
    14:06:25: bits_left=1364
    14:06:25: bits_left=1980
    14:06:25: bits_left=-1
    14:06:25: overread, skip -5 enddists: -2 -2
    14:06:25: bits_left=2251
    14:06:25: overread, skip -4 enddists: -2 -2
    14:06:25: bits_left=2394
    14:06:25: bits_left=2520
    14:06:25: size= 798kB time=29.2 bitrate= 224.0kbits/s
    14:06:25: video:0kB audio:798kB global headers:0kB muxing overhead 0.000000%
    14:06:27: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
    14:06:27: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
    14:06:27: libavutil version: 49.1.0
    14:06:27: libavcodec version: 51.27.0
    14:06:27: libavformat version: 51.12.1
    14:06:27: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
    14:06:27: Input #0, image2, from 'C:\\Documents and Settings\\Administrator\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.3600.0\\menu\\background1.jpg':
    14:06:27: Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
    14:06:27: Stream #0.0: Video: mjpeg, yuvj420p, 720x480, 25.00 fps(r)
    14:06:27: Output #0, rawvideo, to 'C:\\Documents and Settings\\Administrator\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.3600.0\\menu\\backgroundES.mpv':
    14:06:27: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 1000 kb/s, 29.97 fps(c)
    14:06:27: Stream mapping:
    14:06:27: Stream #0.0 -> #0.0
    14:06:27: Press [q] to stop encoding
    14:07:35: video:3088kB audio:0kB global headers:0kB muxing overhead 16.619585%
    14:07:37: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
    14:07:37: INFO: [???] File C:\Documents and Settings\Administrator\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\backgroundES.mpv looks like an MPEG Video stream.
    14:07:37: INFO: [???] File C:\Documents and Settings\Administrator\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\menu.mp2 looks like an MPEG Audio stream.
    14:07:37: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    14:07:37: INFO: [???] Found 1 audio streams and 1 video streams
    14:07:37: INFO: [???] Selecting dvdauthor DVD output profile
    14:07:37: INFO: [???] Multiplexing video program stream!
    14:07:37: INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\Administrator\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\backgroundES.mpv)
    14:07:37: INFO: [???] VIDEO STREAM: e0
    14:07:37: INFO: [???] Frame width : 720
    14:07:37: INFO: [???] Frame height : 480
    14:07:37: INFO: [???] Aspect ratio : 4:3 display
    14:07:37: INFO: [???] Picture rate : 29.970 frames/sec
    14:07:37: INFO: [???] Bit rate : 1000000 bits/sec
    14:07:37: INFO: [???] Vbv buffer size : 126976 bytes
    14:07:37: INFO: [???] CSPF : 0
    14:07:37: INFO: [???] Scanning for header info: Audio stream c0 (C:\Documents and Settings\Administrator\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\menu.mp2)
    14:07:37: INFO: [???] MPEG AUDIO STREAM: c0
    14:07:37: INFO: [???] Audio version : 1.0
    14:07:37: INFO: [???] Layer : 2
    14:07:37: INFO: [???] CRC checksums : no
    14:07:37: INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
    14:07:37: INFO: [???] Frequency : 48000 Hz
    14:07:37: INFO: [???] Mode : 0 stereo
    14:07:37: INFO: [???] Mode extension : 0
    14:07:37: INFO: [???] Copyright bit : 0 no copyright
    14:07:37: INFO: [???] Original/Copy : 1 original
    14:07:37: INFO: [???] Emphasis : 0 none
    14:07:37: INFO: [???] SYSTEMS/PROGRAM stream:
    14:07:37: INFO: [???] rough-guess multiplexed stream data rate : 1255800
    14:07:37: INFO: [???] target data-rate specified : 10080000
    14:07:37: INFO: [???] Setting specified specified data rate: 10080000
    14:07:37: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16022
    14:07:37: INFO: [???] New sequence commences...
    14:07:37: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
    14:07:37: INFO: [???] Audio c0: buf= 0 frame=000000 sector=00000000
    14:07:37: INFO: [???] STREAM e0 completed @ frame 868.
    14:07:37: INFO: [???] STREAM c0 completed @ frame 1215.
    14:07:37: INFO: [???] Multiplex completion at SCR=2631972.
    14:07:37: INFO: [???] Video e0: buf= 0 frame=001182 sector=00001842
    14:07:37: INFO: [???] Audio c0: buf= 2688 frame=001215 sector=00000405
    14:07:37: INFO: [???] VIDEO_STATISTICS: e0
    14:07:37: INFO: [???] Video Stream length: 3687355 bytes
    14:07:37: INFO: [???] Sequence headers: 73
    14:07:37: INFO: [???] Sequence ends : 0
    14:07:37: INFO: [???] No. Pictures : 869
    14:07:37: INFO: [???] No. Groups : 73
    14:07:37: INFO: [???] No. I Frames : 73 avg. size 14403 bytes
    14:07:37: INFO: [???] No. P Frames : 797 avg. size 3298 bytes
    14:07:37: INFO: [???] No. B Frames : 0 avg. size 0 bytes
    14:07:37: INFO: [???] Average bit-rate : 1016000 bits/sec
    14:07:37: INFO: [???] Peak bit-rate : 1866800 bits/sec
    14:07:37: INFO: [???] BUFFERING min 67123 Buf max 136052
    14:07:37: INFO: [???] AUDIO_STATISTICS: c0
    14:07:37: INFO: [???] Audio stream length 817152 bytes.
    14:07:37: INFO: [???] Syncwords : 1216
    14:07:37: INFO: [???] Frames : 1216 padded
    14:07:37: INFO: [???] Frames : 0 unpadded
    14:07:37: INFO: [???] BUFFERING min 15 Buf max 683
    14:07:37: INFO: [???] MUX STATUS: no under-runs detected.
    create sub file....done.
    running menu muxer....14:07:39: MUXRATE =4400
    14:07:39: after read_bmp(): xd=720 yd=480 x0=0 y0=0
    14:07:39: Found EOF in .sub file.
    14:07:39: warning, sub on line 0 starts before 4s, (some players won't show it)
    14:07:39: subtitle duration: -1
    14:07:39: ***************** HERE WE GO EVE.ODD *******************
    14:07:39: MenuType: EVEN
    14:07:39: subtitle_packet_size: 1113
    14:07:39: subtitle_packet_size & 1: 1
    14:07:39: subtitle_packet_size mod 2: 1
    14:07:39: MenuType==""
    14:07:39: MenuType=="EVEN"
    14:07:39: WAS ODD
    14:07:39: subtitle_packet_size++
    14:07:39: final subtitle_packet_size: 1114
    14:07:39: max_sub_size=1114
    14:07:39: subtitle inserted at: 0.178022 sd=0
    14:07:39: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
    done.
    14:07:40: Encoding menu...Done.
    14:07:40: SVCD2DVD: DVDfolders
    14:07:40: -->: DVDFolders creating table of contents
    14:07:40: scanning D:\SVCD2DVD DVD Output\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
    14:07:40: -->: Creating menu for TOC
    14:07:40:
    DVD Folders: Processing C:\Documents and Settings\Administrator\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\menu.mpg...
    14:07:40:
    14:07:40:
    14:07:40: Finalising DVD...Done
    14:07:40: Done: Authoring DVD Folders
    Burning DVD folder
    14:07:40: Burning DVD with ImgBurn...
    14:28:08: Burning ISO...Done
    14:28:08: Done: Burning DVD folder
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok. in the first instance can you email my the image and the audio... i will try it this end. Also can you try choosing AC3 for the menu audio output?
    Feb 2008
    Files on their way Chrissyboy.
    Will try AC3 menu audio, although I think I've already tried it once. Another go won't hurt....
  10. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Thanks for the files.... I have replicated the issue and the problem is that for that particular background a higher bitrate is requred for the menu. I will send you a build to confirm the fix and I'll add it to the next build.
    BTW: No need to test AC3
