  1. Member Carrie-Ann's Avatar
    Oct 2006
    Hi there. I'm not sure if this is the right forum to ask this but I'd like to know if there's any easy, hassle-free way to create animated wallpapers from my library of videos in various formats e.g. avi, wmv, mpeg etc.?
    I'm using Windows XP Home Edition SP2.
    Any suggestions would be much appreciated!
    Apr 2004
    Miskatonic U
    VLC can do it, although you would have to start it manually each time you restarted your PC.
    Read my blog here.
    USA
    And it may use up a fair bit of CPU power to run that in the background and still be able to use your computer for other processes.
    And welcome to our forums.
    Jan 2007
    there is a free program call 'screen swift' it will take swf files and create an exe installer version screen saver
    you then install the screen saver like you would anyother screen savior, even give it away to friends or post it on a fie share site
    like was said animated wallpaper that is there and running while you use your normal desktop, takes a lot of CPU power
    I tried some, went back to static wallpaper and animated screen saviers
