I wanted to convert a film from PAL to NTSC. I did not notice any interlacing in the PAL source so I opened it in GSpot and it said the PAL image was progressive so I just skipped telecide and just used assumefps(23.976) in my .avs file. GSpot says the resulting file is interlaced/top field first with both frames per second and pictures per second as 23.976 and fields per second as 47.95. I haven't checked the video over rigorously with Virtualdub but I did preview the m2v in VLC with none of the deinterlace filters on and did not notice any interlacing.
I've had this happen before and just ignored it but I just wanted to know if I perhaps did anything wrong or if GSpot is not entirely accurate. With other projects I've only checked after I flagged it for 23.976-29.97 with DGPulldown and that said it was interlaced with 23.976 frames and 29.97 pictures per second in GSpot while Nero identified those as "29.97 Progressive (Telecine)".
GSpot isn't always entirely accurate, but...
You have two issues: Whether the contents of individual frames is interlaced (whether they contain one picture or two), and whether the frames were encoded as if they were interlaced (MPEG handles interlaced and progressive frames differently internally). It sounds like the source frames were not interlaced but you encoded them as if they were. By encoding progressive frames in interlaced mode you have degraded the image quality unnecessarily. -
My fault. I thought that "auto select" in the encoder meant that it would select interlaced or progressive based on the loaded video and the arguments in the avs file but apparent "auto select" means select TFF or BFF.
So GSpot should read I/L (even though its really progressive), 23.976 fps, 29.97 p/ps, and 59.95 fields, right?
Tool that gives more info about .mp4 than GSpot
By Wam7 in forum Newbie / General discussionsReplies: 15Last Post: 7th Nov 2019, 04:51 -
Media Info Not seeing all subtitles
By cal_tony in forum SubtitleReplies: 0Last Post: 15th Apr 2012, 22:43 -
Media Info query
By Bully9 in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2011, 08:54 -
wmp win7 not playing certain mpeg1 files, gspot info included
By Rudyard in forum Software PlayingReplies: 6Last Post: 7th Jan 2011, 02:53 -
Media Info and AVISynth
By ZedVamp in forum Video ConversionReplies: 0Last Post: 7th Feb 2009, 14:25
