Hi,
I am needing some advise as to the best possible solution to connect my existing pc and tv. I know neither are very good but sometimes you just have to make do with what you do have![]()
The items I am looking to connect are: -
I have an old CRT TV - Loewe Aventos 100hz which has only Euro A/V Scart connections
Dell Dimension 5150 desktop
Intel(R) Pentium(R) D 915 with Dual Core Processing
XP Home Edition SP2
2GB (4X512) NECC Dual Channel DDR2 533MHz SDRAM Memory
500GB HD
Standard Graphics Card![]()
I would like to be able to watch movies (mainly .AVI, .mkv, DVD, mp4 etc) and listen to music.
I also have SD set top box/DVD/5.1CH Receiver. The DVD/set top box are connected to TV using A/v Scart cables. Both are then connected to Receiver with optical cables.
As previously stated I know that I do not have a good set up but would like to maximise what I do have.
Would very much appreciate anyones input into a cost effective solution to my senario.
Cheers,
redtrigger![]()
Need more def on "Standard Graphics Card"
Does it have S-Video out? Second output?
Also need a link for the TV. Is it something like this?
http://www.avguide.com/products/product-2865/Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
The graphics card I have is: -
NVIDIA GeForce 6150 SE graphics card
Links to TV
http://www.loewe-uk.com/download/pis/Aventos_3772Z_en.pdf
Cheers,
redtrigger
6150 SE seems to be a mobo chipset. What video outputs are offered?
edDV,
You are correct, the 6150 SE is a mod chip and does not offer any outputs
SO I guess I will need a graphics card with outputs and some kind of cable that will connect to SCART!!.
Any ideas
Cheers,
redtrigger -
Newer cards offer DVI-I (includes DVI-D and VGA pins), S-Video and often analog component YPbPr. I'll let others suggest connecting to SCART. Adapters exist.Originally Posted by redtriggerRecommends: Kiva.org - Loans that change lives.
Connecting headphones
By siluet in forum DVB / IPTVReplies: 5Last Post: 14th Jan 2011, 09:22 -
Connecting pc to tv
By hygieneboy in forum ComputerReplies: 6Last Post: 27th Jan 2009, 15:28 -
Connecting HD TV - PC
By 1234567 in forum DVB / IPTVReplies: 16Last Post: 17th Feb 2008, 18:29 -
Connecting tv to PC without a TV-out?
By andyr74 in forum Media Center PC / MediaCentersReplies: 2Last Post: 26th Dec 2007, 23:48 -
Connecting my PC to TV via svideo.
By chronic777 in forum Software PlayingReplies: 2Last Post: 12th Sep 2007, 00:06
