i just picked the dazzle II up yesterday. i have my
cable box connected to the dazzle and the audio connected
from the out on my dazzle to the audio in on my soundcard.
while previewing the tv on the PC, the audio is out of sync
but when i finish recording, everything is in sync. it's only
out of sync while previewing the recording. is this a
common problem with dazzle and is there anyway i can fix
it? thanks.
i get the same problem,i don't worry about it as long as the final product is good.when u use it shut EVERYTHING ELSE down.even virus scan.it makes a difference.
That is not a problem.
Previewing how the MPEG will look on the fly, takes A LOT of CPU power, you probably don't have a fast enought computer to keep up with the preview, which is why the video stutters along while the audio keeps going.
Probably 98% of the people on these boards don't have a fast enough computer to get the preview to look in sync. Probably need a dual 2ghz config to even get the Preview too look like it is an Overlay of the original source.
I don't even know if there are dual 2ghz boards out there.
Currently running a dual Ahtlon 1.4ghz config; too bad I dumped both my crappy Dazzles A LONG time ago.
That is a horrible MPEG-1 & MPEG-2 board when it comes to picture quality, time was though it is a almost convenient. "ALMOST!"
Two Quick Questions about Dazzle DVC 100
By Derangedyeti in forum Capturing and VCRReplies: 17Last Post: 23rd Dec 2010, 23:46 -
Dazzle DVC 90 Capturing
By LangleyM in forum Capturing and VCRReplies: 2Last Post: 19th Apr 2009, 10:42 -
Better than Dazzle DVC-170?
By bmbsa in forum Capturing and VCRReplies: 5Last Post: 21st Sep 2008, 07:18 -
audio sync prob dazzle dvc-150 and virtualdub
By zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 14:34
