Hi,
I got one merraige DVD from my relative from India to here in New Zealand.
When I tried to copy that DVD using Nero then my "Next" button in Nero
is left disabled. Means not allowed me to copy.
Is this the Region Code Problem? Can anybody suggest me the solution!
Thanks,
does it play on your computer?
No region codes normally with burned DVDs. Is it a PAL<>NTSC problem? What's the framerate? You could check that with Gspot, along with other format info. If you just wanted a exact copy, use ImgBurn, Read>Write. Nero can be flaky at times.
But as aedipuss asked, does it play on the computer?
And welcome to our forums. -
I think that usually happens when you haven't done something right, such as not selecting the proper destination drive. Go through it step by step and try again, or tell us step by step what you're doing.
Thank you very much all of you guys,
I tried ImgBurn and it is definitely working. But while writing the Image to disk, it was giving me some error at
around 90% of the process. But it might be something wrong with DVD or there was only 5Gb space left on that
drive D( Not Installation Drive ) while writing 4.47GB of Image.
It was too late at night, I left it there. But I will again try on my PC with Vista which has enough space. Nero was
not allowed to start burning the Image. I think ImgBurn will do the job.
Thank you once again, and if it will also give me error on my Vista PC then will let you know. -
Don't use cheap blanks. What do you use?
I am saving image to hard drive now from original DVD. But the original DVD is from
someone else and it looks cheap.
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 12:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 00:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 11:23
