Is it possible, using TMPGNC DVD AUTHOR to add a music track to the menu title pages...........
				Results 1 to 9 of 9
	Yes. In version 1.6 it may only be included as a motion background: Menu display setting > Motion menu > check Motion menu and Use audio... You will need to render an mpg file containing static image or a movie + audio. Import it by clicking on a menu background.
 I don't know how it is in version 2 as I upgraded to 3. In "Menu edit" option in 3.x there is a separate setting tab for "BGM audio selection".
	"You will need to render an mpg file containing static image or a movie + audio."
 Can you tell me how i can do this...............and what program i need. Thanks so much for helping me out!
	It depends on what version you have....
 TSUNAMI-MPEG DVD Author PRO & TMPGEnc DVD Author 3 with DivX Authoring let you add audio seperately to your menus.
 I know the original two version you had to make an MPG file with either a still photo or video with the audio already added.
	"I know the original two version you had to make an MPG file with either a still photo or video with the audio already added"
 I have a version 1.5, but it will let me use and audio track as the BGM, i just need to know how to add audio to a photo or make an mpeg file of a still photo, cheers for the assistance
	I used to use TMPGEnc, add a photo, add the wav file, then encode it to dvd spec's and it would create the video of the still for the length of the audio file i added.
 I think TMPGEnc will allow you to use the dvd encoding for a limited time then you have to pay for it, and i'm sure there are other freeware encoders you could prob. do it with also, i just don't use many freeware encoders & very rarely when i do.
	Having trouble with this, i have imported a jpeg picture file into TMPGnc plus. and then a WAV audio track, then created a file from the two, BUT the audio doesnt come out on the finished product...............Part of the problem i think, is that the TMPGnc wizard wont let me import a jpeg/BMP image. BUT when i close the wizard down and use the normal program it alllows it, BUT i still get no audio on the outputted MPEG (m2v file) file, Any ideas on whats going wrong
	An M2V file is NOT an mpg, it is JUST the video portion.
 You could always take that M2V and mux it with the original wav file,
 What do you have it set to under "Stream Type"
 The you can open the "Load" button and either load the "DVD (NTSC) template" or the "unlock Template" and adjust the settings manually, if you know what they all need to be set at.
	SORTED, it doesnt come much clearer than that. thanks so much for the info.............
  How return to reference menu after adding a new audio track on a muxed DVDBy alvin68 in forum Authoring (DVD)Replies: 41Last Post: 20th Dec 2011, 13:26
  Menu editing after adding audio trackBy Instant Martian in forum Authoring (DVD)Replies: 4Last Post: 30th Oct 2011, 12:23
  I need a DVR that can record without making a menu pageBy khicks in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Sep 2010, 17:41
  Menu page for DVD RecordersBy padrejo in forum DVD & Blu-ray RecordersReplies: 11Last Post: 27th Sep 2008, 17:54
  Removing and Adding New Audio to Mpeg Video for DVDStyler MenuBy dennis albright in forum EditingReplies: 0Last Post: 25th May 2007, 08:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
