i was wondering which would be the best software to use for dvd guitar instruction videos...i just bought a couple of instruction vid's for guitar and need a player that can easily loop and slow down the vid.....i had an older version of CyberLink Power DVD that came with my PC...........but im not that crazy about it....it glitches and i have to close out and reload....thanks
VLC Media Player is the first that comes to mind. You can adjust the playback speed on the fly with the keyboard controls and set it to jump back or ahead a set amount. Another player might be Zoom Player Pro, but it's payware. I'm sure there are several others. VLC also has the advantage that it uses it's own codecs and will play just about any format, including DVDs.
And welcome to our forums.
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
