Enough of the spec is revealed in manuals on how to use video products. I remember learning a great deal of information simply by reading the help files for DVDit! PE, DVD Studio Pro 1, Final Cut Pro 2, and Cleaner 5, some 6-7 years ago.
				Results 31 to 33 of 33
	Thanks for the leads guys. I'm reading, and reading...
 So it won't work to use a flashlight, mirror, and photographer's lightmeter to determine reflectivity
 Seriously though, this reflectivity thing seems pretty simple in theory. It's just the percentage of light reflected back...
 "Reflectance (Reflectivity): Proportion of incident light that is returned from a reflective surface."
 http://www.mscience.com/gloss.html#R
 If it's as important as you suggest, surely somebody ought to run reflectivity tests on the popular media, at least, and publish the list. That same company does it, presumably for a fee...
 http://www.mscience.com/test.html
 If they can do it, you or I can do it!
	JohnnyBob,
 I hadn't run across the mscience site before. I see they sell 2 "MODERATE COST DVD AND CD MEDIA TESTERS". Both of the testers appear to use calibrated consumer drives, not reference drives. As is mentioned in the "Demystifying the drive" whitepaper, the problems with calibrated consumer drives is what led to the development of reference drives. The "Calibration no substitute for poor equipment design or build quality" whitepaper would allso provide some insight on the matter.
 Considering what they're charging for their testers, and extrapolating what they might charge for a disk test, it probably wouldn't cost all that much more to let AudioDev (the pros) do the testing for you on a CATS system for $240 per disk (minus $70 if you decide not to take the expert analysis). Personally, I would take the expert analysis.
 If there's a comprehensive reflectivity study somewhere, I haven't run across it. It would probably be very difficult to maintain an up to date listing for all the disks made by all the manufacturers in all the facilities.
  Samsung SH-S243D DVD writer - CD media burn qualityBy onland in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Feb 2012, 23:52
  Templates for popular printable DVD mediaBy stiltman in forum MediaReplies: 60Last Post: 4th Jan 2011, 09:20
  Media does not burn at advertised speeds.By nick101181 in forum MediaReplies: 14Last Post: 27th Feb 2010, 17:44
  Quick Media Converter lifehacker.com most popular free windows app 2008 ?By balou in forum Latest Video NewsReplies: 77Last Post: 17th Mar 2009, 03:09
  Can't get rid of PIO, Slow burn speedsBy ER_Doc in forum DVD & Blu-ray WritersReplies: 9Last Post: 19th Jul 2007, 23:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
