hi,
i have been having a problem with the audio of a copy of lotr divx..
it was in 4 parts and i joined it together with no real hassles, but when i used TMPGEnc to convert to vcd the audio at the start is in sync but as u go more towards the end it becomes more out of sync... please help me and rid me of this nightmare....![]()
Is the large DivX file (with all the parts appended) also starting out with the audio synched, but falling behind the video as time goes on?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
no the divx has no sync problems at all... i wish it was the case cause then that wouldnt be so hard to fix... thanx for prompt response
Try this open up v-dub under video select direct stream and under audio select full compression. then go to conversion and select 44 hz. after that go to file and save avi. This will give you a larger file but tmpgnc likes uncompressed audio. Before you encode play the file to make sure it is in sync.
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 15:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 03:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 01:23 -
In VirtualDubMod, if the audio is longer to video would it cause sync probs
By breadbin in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 07:35 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 21:29
