  1. What's up...
    I was wondering..can i convert a partially downloaded
    avi to VCD and watch it on DVD without any problems?
    Thanks in advance...
    in order to collect the reward you need
    at least 51 percent of the carcass
    -----APU-----
  2. check out http://www.divx-station.com
    they have a program that can fix partially downloaded avi files.
    Fix the ************ and convert it to mpeg in tmpg..
  3. Or just use divfix from this site..i believe it's under the tools section and rebuild the index. Then you can convert.
