After looking at lots of posts and also reading mnfg. specs,
I thought that instead of waiting for updated Bluray players, I would just
get a Ps3. Since I have no intention of using it for games, does it
matter about the hard disk size.
Seems like Ps3s range from 20 gb to 80 gb. Is one as good as another for playing
Bluray movies?
Tony
Hard drive size has no influence on playing of Blu-Ray movies but does influence how much other stuff you can store: pics, mp3s, vids etc. If you think of the PS3 as a media centre, than hard-drive size becomes important. Internal hard drives can be replaced with larger ones (5400rpm).
You can connect an external USB hard drive formatted as FAT32 to the PS3 and it will use it like it's own.
If you plan on using an external HD then there's no real need for a large internal drive - if you don't have a spare external HD then get the largest HD model you can find.Regards,
Rob -
Rhegedus,
Rob, thank you very much.
I have lots of sub 100 gb drives including having some
USB drives, so I guess I'm good to go.
Thanks,
tony -
One of them don't have wifi, and newest one have no compability with PS2. Just a warning. Make sure you know the difference. But if you just use it as bluray exclusively and play some PS3 game locally then it does not matter. MAybe you just need to wired if you want internet connection.
Bluray media playing on PC but not on PS3 .. !!?!
By ahmadka in forum MediaReplies: 2Last Post: 17th Aug 2011, 02:21 -
PS3 Bluray ISO Mounting
By Westie69 in forum LinuxReplies: 1Last Post: 7th Jan 2011, 18:18 -
Bluray backup on PS3??
By bagmand22 in forum Blu-ray RippingReplies: 1Last Post: 24th Dec 2010, 08:01 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 14:05 -
How to get my BluRay HD backups to PS3
By gga in forum Blu-ray RippingReplies: 6Last Post: 13th Feb 2009, 17:43
