i schedule it the i restart and my computer boots up like normal, but disk check never runs. is there a setting i need to check and if so where is it?
my whole life flashed be fore my eyes,and i wasnt even dead yet.
I just tried it with one of my Vista computers on the (C) boot drive. Clicked, 'Schedule Disk Check', then restarted and it ran CHKDSK after BIOS finished. I'm not sure why your system wouldn't do the same.
And I wish I hadn't tried it.
I forgot I have a 320GB boot drive. This may take a while.
well it worked once but thats it.
my whole life flashed be fore my eyes,and i wasnt even dead yet. -
Are you running Norton Antivirus by any chance? Norton has been known to block chkdsk.
Believing yourself to be secure only takes one cracker to dispel your belief. -
no i dont have notrton. problem has been solved ty for your reply
Vista 32 bit ... Disk full? but only 35GB files on a 108 GB c:\ partition.
By edDV in forum ComputerReplies: 6Last Post: 6th Jul 2010, 02:55 -
Why would there be disk activity in sleep mode on Vista?
By yoda313 in forum ComputerReplies: 6Last Post: 4th Jun 2009, 21:57 -
Check out this Vista-like search bar for Windows XP
By freebird73717 in forum ComputerReplies: 11Last Post: 22nd Mar 2009, 12:58 -
What is the Check Disk Command
By videocheez in forum ComputerReplies: 2Last Post: 19th Oct 2008, 18:27 -
Vista and intel AHCI disk controller problems.
By ofbarea in forum ComputerReplies: 8Last Post: 20th Nov 2007, 20:36
