Hello, normally I use bitrate, is there any advantage to using a target quantizer for converting mpeg 2 files recorded off standard definition digital cable?
As with any encoder, providing a bitrate and encoding either CBR or 2-pass VBR will give you a known file size, possibly at the sacrifice to quality if the bitrate is too low. Quantizer gives you a known quality level (relative to the source) but with an unknown file size. If quality is the most important factor then use target quantizer encoding and live with the file size. It will also be faster than 2-pass VBR encoding as it is a single pass process.
Read my blog here.
Xvid Setting: 1pass Quantizer vs Bitrate Mode, vs 2pass => Quality
By carlaron in forum Video ConversionReplies: 12Last Post: 4th Oct 2010, 07:12 -
XVid Target quantizer / Bitrate Analogy
By drgt in forum Video ConversionReplies: 3Last Post: 19th Sep 2010, 11:33 -
Is DivX Quantizer 1 Loseless?
By Anakin in forum Video ConversionReplies: 6Last Post: 15th May 2009, 22:01 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
