How can i solve this problem...
I don't know how to make my media player play only my french audio track... I'm hearing both english and french tracks at the same time on some .avi (divx or whatever...) files... This problem is happening some times to me, not too often, but i want to know what to do next time.
Thanks for the help !
You might try installing Haali Media Splitter, if you don't have it installed already, and see if that will give you the option to switch between audio tracks.
If the AVI actually has the audio tracks recorded as one side (left or right) of a single stereo audio track, however (doubtful), that's a different story.If cameras add ten pounds, why would people want to eat them? -
A software media player? If so, a player like VLC can select a particular audio track for playback or just play one side of a split stereo channel. Or you could also process your AVI type files through VirtualDub and disable the unwanted channel, then save both the audio and video out in 'Direct stream copy' mode for a quick permanent cure.
And welcome to our forums.
Remove Language track
By GeorgeD123 in forum DVD RippingReplies: 9Last Post: 9th Jun 2011, 00:08 -
Can you add a second language audio track on DVD workshop 2
By uncle mikie in forum AudioReplies: 1Last Post: 15th Jan 2010, 00:22 -
Forcing English as the audio track to choose while playing mkv
By Wolverene in forum AudioReplies: 0Last Post: 30th Nov 2007, 11:35 -
Help extracting language track from dual audio video.
By ebisoba in forum Video ConversionReplies: 5Last Post: 9th Sep 2007, 14:53 -
Audio track in a different language
By hampushello in forum AudioReplies: 5Last Post: 17th Jul 2007, 22:50
