I got some DVD's mailed to me from the UK and they said they are "Region 0" but they won't play on ANY of my dvd players. They will play on my computer. I've tried simply copying the disc and it didn't work, I've tried copying it to my hard drive and then burning them to DVD just like a normal one where my region is on 1. I've tried using decypter even though it is not encrypted but I'm getting an error around 85% that it reached it's memory capacity but it's only 3gb? I've tried using Nero and I've tried using Sonic Record Now...I've looked at the "Reauthor" on the DVD Decrypter but don't understand what/how it works. I can't remember if I used DVD Shrink and just not shrink it as Nero is my default on that.
I've tried a convertor which I "THINK" may have worked but it was a trial version and you can only do 1 chapter at a time and there is like 200 total chapters. Any freeware convertors and is this even what I need?
Any other thoughts? I'd rather just get these to work as the cost of a few discs is better than shipping back to the UK.
It's a PAL problem. The easiest thing to do seeing as you have Nero would be to use NeroVison Express (I still use ver. 6) and 'Import' the PAL disc. It will take a while then let it re-encode to NTSC. See if the quality suits you. No menus or subs though.
Otherwise there are probably a few hundred posts and some guides here you can search for on converting PAL to NTSC.
https://www.videohelp.com/guides?searchtext=pal+to+ntsc&tools=&madeby=&formatconversion...or+List+Guides
Burn from to DVD but what format to play on tv?
By Claxlast in forum Authoring (DVD)Replies: 5Last Post: 18th Mar 2011, 17:57 -
How to burn/play DTS audio cd's
By arraf in forum AudioReplies: 16Last Post: 9th Sep 2009, 13:55 -
Converting WMV to burn on DVD to play on DivX
By ez2cy in forum Video ConversionReplies: 30Last Post: 20th Dec 2008, 04:54 -
PAL DVD will burn but not play
By vhsreject in forum Authoring (DVD)Replies: 6Last Post: 5th Sep 2008, 03:07 -
I need to burn a iso onto a disc to play my game.
By krisyrfc in forum DVD & Blu-ray WritersReplies: 5Last Post: 19th Jan 2008, 13:37
