From the manual book of TV, is not clear how to do that. There is a output on my Tv named "pc output" .My PC has DV outputs( one of them works with LCd monitor) What cable I need to use in this case? Thanks in advance.![]()
Results 1 to 17 of 17
It's probably a VGA connection. You can use a DVI to VGA converter cable but check first if you don't have any HDMI or DVI connections on your TV.
D-sub is 15 pin VGA. It can support DVI or HDMI as well. Let us know what TV and what video card you want to connect.Originally Posted by 1234567
What is the laptop PC output connector?Originally Posted by 1234567
Does it look like this?
http://en.wikipedia.org/wiki/DVI
or this
http://en.wikipedia.org/wiki/VGARecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
No, is not not laptop. Is a desktop PC, HP media center. The PC has 2 DV outputs. The Tv has D sub input. So what kind of cable a need to buy?Originally Posted by edDV
The display card DVI-I connector has pins for DVI-D and VGA. Most display cards cone with a DVI-I to VGA adapter like this. In that case you need a VGA cable.Originally Posted by 1234567
If you can't find the adapter, you can buy a DVI-I to VGA cable. If the cable is over 10ft. make sure it is a good grade with double shielding.
@edDV
My friend. How much will cost me this DVI to VGA cable( I need it near to 3.5-4 m)?
$5-$50 depending where you buy it. 4m (15ft) can be found in any computer store or online.Originally Posted by 1234567
http://www.cablestogo.com/product_list.asp?cat%5Fid=2801&sortType=length&sortDir=ASC&c...FQ8nawodgWmJfg
http://cgi.ebay.com/15ft-DVI-to-VGA-cable_W0QQitemZ260065966639QQcmdZViewItemRecommends: Kiva.org - Loans that change lives.
Is possible to connect the Pc from DVI output, with TV- HDMi input?Originally Posted by Video Head
Yes, just use a DVI->HDMI cable. Like this one:Originally Posted by 1234567
http://www.newegg.com/Product/Product.aspx?Item=N82E16812189056 -
Make sure your video card in your computer is HDCP capable otherwise using a DVI to HDMI cable will not work.Originally Posted by jagabo
VGA is the more fool proof connection and cables are cheaper.
- no overscan
- Standard computer display sizes (e.g. 1024x768, 1366x768)
DVI-D to HDMI has several issues but offers potential for higher quality.
- overscan
- HDCP
- 1080i/1080p/720p/480p/480i video sizes
- potentially expensive cablesRecommends: Kiva.org - Loans that change lives.
It will work for everything except Blu-ray and HD-DVD.Originally Posted by budz
Ummm....I don't think so.....I've already tried hooking up one of my computers to my Panasonic LX70 HD LCD TV by using a HDMI to DVI cable that I got from monoprice.com. All I got was a blank tv screen. I was told by monoprice.com that the video card has to be HDCP capable in order for it to work on a HD LCD TV. Which does make sense. Therefore I'm assuming by using a Blu-ray or the soon to be dead HD-DVD drive from a computer would be able to playback on a HD LCD TV as long as the video card is HDCP capable.Originally Posted by jagabo
Connecting headphones
By siluet in forum DVB / IPTVReplies: 5Last Post: 14th Jan 2011, 09:22 -
Connecting pc to tv
By hygieneboy in forum ComputerReplies: 6Last Post: 27th Jan 2009, 15:28 -
Connecting PC to TV
By redtrigger in forum Media Center PC / MediaCentersReplies: 5Last Post: 7th Feb 2008, 14:06 -
Connecting tv to PC without a TV-out?
By andyr74 in forum Media Center PC / MediaCentersReplies: 2Last Post: 26th Dec 2007, 23:48 -
Connecting my PC to TV via svideo.
By chronic777 in forum Software PlayingReplies: 2Last Post: 12th Sep 2007, 00:06
