is there any programs that will allow me to capcure something from the tv stright to a dvd like a stand alone? and will allow me to select the lenth like one hour up to six hours like a stand alone? I have a cheep tv card installed on my pc and when I capure something it breaks it down into seperate files on my hard drive, dont know how to capcure an entire show with out it breaking it apart (like a ufc match 5 some hours long} my tv card issbt-tvfm/ sn:808971481986) HELP and thanks for any and all advice
http://www.ulead.com/learning/dmf/dmf4_05_1.htm but I don't think it has any 6 hours mode(low quality).
You cannot put more than 4 hours on a DVD.
Past 4 hours, it looks worse than VHS, and is less than half the resolution of VHS.
1-2 hours is so-called "DVD resolution" with DVD bitrates. It's higher resolution for film and DV transfers.
3-4 hours is about what your normal tv sources look like -- cable, VHS, broadcast, satellite, etc. These should use 352x480 with medium bitrates (some crappy machines use 720x480, which looks horrible at the lower bitrates).
4-6 hours is crap. VCD or lower quality, lots of blocks, really blurry videos, worse than any VHS tape (even at EP/SLP mode) ever was. It's about the quality of Youtube video at best. Yuck.
Capture cards were not made to go straight to DVD.Want my help? Ask here! (not via PM!)
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 8th Oct 2011, 00:01 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
