I need a DVD authoring program to create simple DVDs for some projects I'm busy with.
My source videos are provided to me on DVDr so extract the VOBs to my hard drive. I already have an application that allows me to edit the VOBs (i.e. cut sections, apply fades and transitions between scenes etc). I then save the project as VOB files.
Features I need:
1. Import videos direct from VOBs
2. Import several individual videos as seperate titles
3. Create chapters in each title
4. Create a simple menu (add my own background image, display volume title, list titles)
The application I use for editing does a great job but when it comes to authoring it isn't very good. I don't need anything fancy, just to be able to burn compilations as specified above. Please don't suggest Nero as I've used that for a long time now and I'm sick of the little problems I keep having with it.
TMPGEnc DVD Author should be able to do all that you list. It will also do the cutting of sections so you don't have to do that beforehand.
However, I don't believe it will do the fades and transitions.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I'll try it, thanks for the quick reply. I'd rather do all the editing separately anyway.
Looking For Software to Create Menu- w/ Fade Transitions Between Chapters
By restmin in forum Authoring (DVD)Replies: 2Last Post: 13th Apr 2011, 17:36 -
Looking for free DVD video editor that will create chapters & titles
By Brent G. in forum EditingReplies: 1Last Post: 22nd Feb 2009, 03:25 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36 -
How create menu to Vobs ??
By Seasonal in forum Newbie / General discussionsReplies: 8Last Post: 23rd Sep 2007, 15:10 -
What program to use to Create a DVD & Menu from FCP.
By DigitalGuard in forum MacReplies: 2Last Post: 1st Jul 2007, 17:29
