Results 1 to 9 of 9
    Oct 2005
    Toronto, Canada
    Can anyone recommend a simple but good tv-tuner software? Perhaps there is a thread on this already, but I couldn't really find what I was looking for.
    Advise?
    Beaker14
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Do you mean PVR software?
    Check for support for your specific tuner.
    GBPVR is simple and free.
    BeyondTV and SageTV have more features.
    http://www.kiva.org/about
  3. Member Nitemare's Avatar
    Jan 2003
    VirtualDub is free and works great. Plenty of guides for learning how and achieving best quality. Though the software that came with the thing is probably the best.
    I'm assuming that you want to capture and not merely watch...
    Even a broken clock is right twice a day.
    Oct 2005
    Toronto, Canada
    Yeah...PVR is what I meant. I had CyberLink PowerCinema (came with card), but it ran quite slow and crashed on me. I'm just looking for something to record...doesn't have to be high end or anything. I'll check out GBPVR.
    Thanks,
    Beaker14
    Oct 2005
    Toronto, Canada
    OK...here's something I didn't think of...I have Pinnacle Studio Plus...is there PVR capability with that? Perhaps Pinnacle has such software as well?
    Beaker14
  6. Member edDV's Avatar
    Mar 2004
    What is the tuner card?
    Better to have a tuner with hardware compression on the card.
  7. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    I have been trying out Chris-TV..So far it works Great with my ATI 650
    Sep 2006
    WatchHDTV is a free program to watch, timeshift, and record OTA HDTV with some Windows XP compatible HDTV Tuner cards. WatchHDTV is the main program for viewing and recording HDTV. WatchHDTV Play is a file player to play any recordings made by WatchHDTV. WatchHDTV Scheduler is the scheduler and silent recorder for WatchHDTV. For ATI HDTV Wonder users, plug-ins are also included to use with the Remote Wonder.
    See:
    http://watchhdtv.net/program.aspx
    Oct 2005
    Toronto, Canada
    Can't remember exctly what card...it an ASUS 'My Cinema' card or something.
