cheers
I haven't done this in a very long time.
w Yade X I can select a VOB and make three files:
w 'save VOB' i get the file called ABC.vob. qt, no sound
w 'save streams' I get two files: ABC.m2v and ABC.ac3
then I guess I combine them somehow? was it w Streamclip?
is there an easier way?
cheers and thanks again
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card -
QuickTime Player doesn't play sound in muxed MPEG-2 files with AC3 audio (such as .VOB).
You could open the VOB file in MPEG Streamclip and 'Convert to MPEG with MP2 Audio' (which will convert the audio), to make a file that will play with sound in QuickTime Player.
However, QuickTime Pro will not convert (Export) audio (any kind) from muxed MPEG-1/MPEG-2 files. So, if you plan to convert further, you should look into other tools. MPEG Streamclip among them. -
This is a great tip and I appreciate it.
I DL'd the latest Streamclip (1.9) and tried as you suggested
I got a ABC.mpeg file, however, afer opening that, QT chrashed.
QT v 7.3
should I try oher conversiobn w SClip?
cheers and thanks again!MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
MPEG Streamclip
G4dual 2GB
AlchemyDVR card -
what are you trying to do exactly?..i use Yade without any problems...
Originally Posted by rotuts
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
VOB to DV last VOB file finishes in about one second w/no data
By Gizmology in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 17:39 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 05:44
