Page 2 of 2
FirstFirst 1 2
Results 31 to 34 of 34
  1. Oh, I believe you can use TSCV or VCDEasy with the SeVCD/SxVCD, and regarding Nero, you can get it from www.ahead.de
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  2. I have now used the PAL enhanced SeVCD template with encoded a 82min film to 770MB - is this about wright ? I assumed this would not fit on 1 700MB CD. Looked at another discussion thread and it suggests that you can fit 800MB of (S)VCD on a CD. Is this true?
  3. an 80min/700mb CDR can accept 800mb of Video encoded material, so the file is well under the file size, and yes, it's true, you can put 800mb on a 700mb CDR media.
    I would suggest however, you use a CDRW to test the SeVCD before you burn it on a regular CD, just to make sure it works on your DVD Player.
    Best Regards,
    Sefy Levy,
  4. an 80min/700mb CDR can accept 800mb of Video encoded material, so the file is well under the file size, and yes, it's true, you can put 800mb on a 700mb CDR media.
    Best Regards,
    Sefy Levy,
