Do you prefer PS/2 or USB connection for your mouse & keyboard?
Results 1 to 12 of 12
"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
I don't prefer either. I just choose the hardware that I like/want and then use whichever connection type that it uses.
Google is your Friend -
I use KVMs so I use PS/2 connections. I hate the USB KVMs
Got to listen to that windows sound of the USB being disconnected everytime you switch is a real pain -
Well both are OK to use. Until Windows looses drivers and USB keyboard does not work. The only way to get it back again is to put back PS2 k/b. Boot windows then boot down again and plug USB back. Then it finds drivers again. Thats what I found anyway.......
Keep going till you get it right!!! -
I prefer USB, but I have the same problem at times with losing the USB connection to the device, so I use PS/2 more often.
For me it is easy. If the computer has PS2 then that is what I use. Why tie up a limited resource, USB ports, when there is no other real use for the PS2 ports. The only time I use a USB Kb or Mouse is if that is all the computer has.
You will never be able to move the mouse or type to fast for either port.
The one benefit that USB has is that it doesn't have tiny pins that can get bent by careless users.
I have been using the same PS2 Kb/Mouse at work and unplugging and plugging day after day as the computers to be worked on change. No Problem. -
True, but also with PS/2 you can plug the keyboard into the mouse jack and visa versa and have strange results.Originally Posted by TBoneit
Done that a few times.
USB seems to understand the KB and mouse differences a little better.
Other, usually minor, problems with USB is that other devices on the USB bus may cause problems with a USB KB or mouse. I don't know if that is a polling issue or a bandwidth issue. -
I use ps2. Just simply because I want to free up all my usb ports for other stuff.
Though I am actually using the ROCKBAND usb 4 port adapter for my vista pc. It works fine even though it says "xp" and for "use with rockband only"
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I also prefer PS/2 because I don't have to worry about 'legacy' issues and it keeps my USB's free.
Most of my mice are USB, but I have those little green adapters to plug them into the PS/2 port."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
USB.My work PC has only PS/2 available so I use that.But at home USB.Probably because it's newer and it lets you hot-swap devices.
A good rule of thumb is if you've made it to thirty-five and your job still requires you to wear a name tag, you've made a serious vocational error. Dennis Miller
Keyboard/mouse set with long cables?
By meneedit in forum ComputerReplies: 13Last Post: 5th Feb 2011, 14:14 -
Lifemedia Htpc IR and usb wirless mouse/keyboard conflicts
By craig198 in forum Media Center PC / MediaCentersReplies: 0Last Post: 2nd Feb 2011, 21:56 -
UBuntu, workpane crashed, mouse active ... keyboard recover?
By edDV in forum LinuxReplies: 3Last Post: 22nd Oct 2010, 04:22 -
can anyone recommend a wireless keyboard and mouse combo?
By mrgain in forum ComputerReplies: 3Last Post: 15th Jul 2009, 12:00 -
Are you using padding or cushioning devices with your keyboard/mouse?
By yoda313 in forum PollsReplies: 9Last Post: 16th Jul 2007, 16:59
