What if I'm capturing on a PC with more then two cores ?Lagarith compresses well but may be slow with too few threads (your profile says dual core). HuffYUV doesn't compress as well but may be faster with few cores. There's a multithreaded variant which may be worth trying. Speed will be important if you're capturing 1920x1080 RGB at 30 frames per second.
What is outside my ball park, and what do you mean when you say 'inside my ball park' ?Best here will be a matter of personal choice. There are many programs that use x264 as the h.264 encoding engine. They differ mainly in the user interface, ranging from simple (few options, not very configurable) to complex (many options, very configurable). Several have been mentioned already. Handbrake or XMediaRecode may be in your ballpark.
Results 61 to 69 of 69
Help Me: guys i downloaded a show blu-ray, and i wanna put in my Tablet. Then i got MeGUI, bitrate 1000kbps is perfect but when i put in 500kbps is horrible. what i should do? cuz in this website http://www.minishares.org/ the tv shows have 500kbs bitrate and resolution is perfect (42min in 150mb mkv).
for exemple: this mediainfo is from Tv Show REVENGE
Video
Format : AVC
Format profile : High@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 29s
Nominal bit rate : 435 Kbps
Width : 848 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.045
Writing library : x264 core 130 r2273 b3065e6
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.10 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=435 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
the resolution is perfect, then i created the same encoding settings to my BD Show and when i queue 500kbps the resolution is terrible.
i don't understand, please help me. -
Buy your tv series instead of downloading warez. And don't hijack old threads. Reread our rules.
But if you are ripping from your OWN blu-rays be sure to LOWER the resolution: ANd you will get BETTER quality from real blu-rays instead of already heavily compressed/shrinked downloaded video.
Width : 848 pixels
Height : 480 pixels
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 16:22 -
H.264 encoder with TS muxer
By kary.sharma in forum Video ConversionReplies: 1Last Post: 30th Dec 2008, 02:35 -
First release of DivX h.264 encoder
By kosmonautbruce in forum DVD RippingReplies: 1Last Post: 25th Aug 2008, 14:15 -
Installing H.264 Codec Encoder
By hzgg2 in forum EditingReplies: 2Last Post: 20th Jul 2008, 14:47 -
H.264 AVC Encoder
By AusTaylor in forum DVD RippingReplies: 1Last Post: 19th Dec 2007, 01:50
