Which one would you consider best, amongst all encoders, freeware or paid, software or hardware?
Results 1 to 30 of 69
Out of all the ones I have tried - I settled for Jesterware. Currently have both DVD to iPod and DVD ripper Pro. Both encode to H264 with fantastic results.
The latest release of DVD Ripper Pro can use all 4 cores on my Q6600 with superb results. Previouse AMD X2 4600 encoded a film in 5-6 hours. New Q6600 does it in 45mins. Output quality is fantastic and able to retain AC3 5.1 sound.
Support is also first rate - any questions or problems and the staff at Jesterware are quick to answer.
I am not saying I have tried every encoder, but this one is easy to use with very good results. IMHO better than most. I would recommend it to anyone. -
Can those encode HD avi or HD DV files?Originally Posted by eon_designs
Can it encode HD avi or HD DV files on the fly (real time)?Originally Posted by Baldrick -
If your system is fast enough, you can do real time HD x264, but you'll need an 8 Core Mac Pro running XP to do it.
https://forum.videohelp.com/topic336716.html
A hardware encoder for h264 HD exists from MainConcept - http://www.mainconcept.com/site/developer-products-6/sunryze-hd-6093/information-6102.html?L=54963 -
Soopafresh wrote:
A dedicated "supaakonpyutaa" would be even better ^_^If your system is fast enough, you can do real time HD x264, but you'll need an 8 Core Mac Pro running XP to do it. -
Thanks.Originally Posted by Soopafresh
This isn't an hardware encoder, it is an SDK. -
This thread is fairly old, what H.264 codec is the best that is free for 2013, that does 720p ?
then x264 should be fine,.. (there's a library available, a CLI, multiple GUIs for it, a vfw version,...)
http://forum.doom9.org/showthread.php?t=167525 might also be an interesting read. -
x264vfw is a VFW version of x264. It will work with any program that uses Windows's VFW API for encoding video. VirtualDub, for example. I usually use one of the command line builds (fed via an AviSynth script) x264 CLI. There are many GUI front ends for x264. Like XMediaRecode, Handbrake, Xvid4PSP, MeGUI, etc.
Latest bred of mainconcept or rovi are the finest because they keep sharpness intact even in low bitrates comparison to x264.
The compressor posted in post #14 is the same as x264vfw ?
MSU has been doing annual h264 software comparisons for years. Here's a link to the current (8th) one:
http://www.compression.ru/video/codec_comparison/h264_2012/ -
No. VFW is the antiquated, deprecated (by Microsoft), Video For Windows API for AVI files. Some programs still use it though. VirtualDub being one of the most notable. I think Sony's Vegas uses VFW when saving as AVI files.
I think it depends somewhat on your skill level. There are several very good encoders that are recommended by the really knowledgeable video geeks here that I don't think are suitable for newbies.
For the less skilled I'd recommend handbrake. Or vidcoder ... same encoder, different interface. A number of very knowledgeable people here like it better. I like handbrake better myself. Either one has the best compromise between power and ease of use I've seen.
I would recommend never ever assuming a program like an encoder that's paid software is going to be better than a free one. One of the big dirty secrets of the computer business is that there are tons of paid programs that are just front ends for one or more free programs with a prettier looking interface. Which often doesn't work as well. -
You started out graverobbing this old thread by stating:
"This thread is fairly old, what H.264 codec is the best that is free for 2013, that does 720p ?"
So yes, you gave the impression.
Beggars need to be careful that they aren't choosy. -
Any hw accelerated h.264 encoder for windows like Elgato turbo.264 HD
By chicken264 in forum Video ConversionReplies: 3Last Post: 14th Apr 2011, 17:22 -
H.264 encoder with TS muxer
By kary.sharma in forum Video ConversionReplies: 1Last Post: 30th Dec 2008, 03:35 -
First release of DivX h.264 encoder
By kosmonautbruce in forum DVD RippingReplies: 1Last Post: 25th Aug 2008, 15:15 -
Installing H.264 Codec Encoder
By hzgg2 in forum EditingReplies: 2Last Post: 20th Jul 2008, 15:47 -
H.264 AVC Encoder
By AusTaylor in forum DVD RippingReplies: 1Last Post: 19th Dec 2007, 02:50
