What is the best way to get good muxed audio when doing multiplexing? I have found a way to change the audio bitrate in x264 .mkv's in an attempt to take about another 200 mb off of a movie file I am trying to edit to burn to disk. I have the options of the following ...
I tried muxing one to WMA Audio ENcoder codec at 8000hz coming from a whopping 48000hz in the first recording.. I dropped 1.2 gigs in file size havent tested audio quality difference yet but off those codes what would you reccomend or do you have any tips I only want to take off about 2-300 megs and keep the great audio so I can fit on a disk I already cut out 400 megs of video I cant cut anymore video any ideas? Basically I want to keep high quality audio and just take off a couple hundred megs is there anyway to keep it at 6 channels too? I only see 2 channel options in my muxer... I have already cut all the video and cant cut anymore vid so this seems a better option then converting the vid anymore.. any help?[/list]
I did a Mainconcept (Adobe2) version the audio sounds great... However.. only 2 channels any suggestions?? do current hardware now adays emulate 2 channel to 6.1 or 7.1 fairly well or is there a big dif in 2 - 6 channel encoding....
Help? No size is shown for video or audio file.
By thezanny in forum Video ConversionReplies: 5Last Post: 10th May 2011, 04:28 -
Audio out of sync after cutting scenes from an MKV file with Avidemux
By kr1ge in forum EditingReplies: 1Last Post: 23rd Oct 2010, 14:08 -
Audio File Size Calculator
By onesikgypo in forum AudioReplies: 1Last Post: 13th Sep 2010, 09:14 -
file size after stripping audio from DV
By dADDo in forum AudioReplies: 6Last Post: 10th Mar 2008, 22:58 -
mkv file audio muxing problem
By shun in forum EditingReplies: 2Last Post: 23rd Feb 2008, 08:15
