Ok, I am using AllToAVI right now and I load in the RMVB file and it said "could not determine the parameters of the video, please manually specify". Also, when I am at the screen to set up the conversion it doesn't give me any data on the video I am converting, it shows nothing. For some reason the FPS is listed as "4A 40". I fill in the details of the conversion and then I start the conversion but nothing happens. The progress bar comes up for an instant and then goes awaya and nothing happens.
Also, I am unable to play the videos in Media Player Classic using CCCP. Is there a codec or something that I need to download?
Please help!
D:
Ok, I guess I just needed to download RealPlayer. However I am still having a problem. For some reason the video comes out and it is longer than the original. I don't know what to do to fix this, the audio seems fine. Also, it says that the FPS is "4A40" in AllToAVI but when I look at the videos properties in Media Player Classic, the FPS looks to be 24 FPS. How can I control the FPS with this program?
rmvb with chinese characters won't play?
By js2k in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2009, 11:39 -
Convert rmvb to AVI
By pchan in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 04:09 -
New MKV File-convertxtodvd won't convert it.
By jbitakis in forum Video ConversionReplies: 17Last Post: 4th Feb 2009, 14:51 -
rmvb file crashes every program when try to convert, can it be fixed?
By whatsmyname in forum Video ConversionReplies: 11Last Post: 28th Jul 2008, 21:55 -
How do i convert rmvb to wmv?
By jimnim in forum Video ConversionReplies: 1Last Post: 8th Jun 2007, 23:22
