Hello again everyone!
My question this time could be simple, could be very complex. I don't really know.
I have a camera (Canon HV20) that shoots in 24P at 1080i. In Premiere, my editor of choice, it has presets for 24P projects, and for 1080i projects, but when I edit in the 24P project, I have to super reduce the image to get it down to fit into the screen, and in 1080i projects, the only available framerates are 25 or 29.97.
I've tried making a custom project thing, but the options stay at 25 or 29.97, and 24 or 23.976 (or whatever those decimals are) are not options at all.
Is there a way to rig Premiere to have a project that's both HDV 1080i AND 24P?
Very complex unless you have experience doing inverse telecine with odd cadence.
The HV20 and other 24F camcorders must pad out 24 fps (23.976p actually) to 29.97 1080i by adding fields. Their priority for adding fields is to minimize jerky direct 1080i playback rather than making inverse telecine easy. Pro 24p camcorders on the other hand use a 24PA process that is supported by Premiere Pro CS3 and Vegas.
24p/24pa explained.
http://www.adamwilt.com/24p/
For the HV20/HV30 see this overview/tutorial.
http://eugenia.gnomefiles.org/2007/07/13/canon-hv20-24p-pulldown/
PS: More general reference on 24p
http://www.24p.com/reference.htmRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I haven't looked for other solutions since Nov. I was hoping the Vegas 8b update would add HV20-24f support.
I hope someone else has a more streamlined method.Recommends: Kiva.org - Loans that change lives.
removing 29.97 pulldown and deinterlacing for 24p editing
By spicediver10191 in forum EditingReplies: 4Last Post: 19th Apr 2012, 22:26 -
24p source to 24p DVD - am I doing it right?
By Killer3737 in forum Video ConversionReplies: 30Last Post: 14th Oct 2011, 17:40 -
Exported 1080i Premiere Pro CS4 sequence - out of sync
By nitrous in forum Software PlayingReplies: 9Last Post: 18th Oct 2009, 12:16 -
24p -> pal -> ntsc back to 24p
By StrobeLightEpileptic in forum Video ConversionReplies: 1Last Post: 13th Aug 2009, 23:56 -
HV20 1080 24P project in Premiere Pro CS3
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 7th Feb 2009, 17:23
