i've been trying to convert some of my divx movies to ipod compatible format.
when i convert using the ipod or iphone presets i get a small file that is full length but is just white. i've change my encoder to mencoder and it will convert to a watchable file in quicktime, but says not valid movie for ipod when i try and move it to my ipod. the white file will move to my ipod. i can't believe i am the only person this is happening to!?
had same problem on both my mac book pro and mac pro
thx
daniel
Does your DivX AVI play in QuickTime Player?
Do you have the QuickTime DivX decoder component,
or similar 3rd party MPEG-4 ASP codec installed?
The iPod/iPhone presets default to decoding with QuickTime,
which means video decoding will fail if QuickTime can't play the source video.
You could try unchecking Decode with QuickTime (Options tab),
or you could expand QuickTime's decoding ability by adding a codec.
i have VLC installed. i have my AVI files set to play through that.
also mplayer will play the to be encoded divx files when i hit "play" in the upper right hand corner of ffmpegx.
the resulting encoded .mp4 will play in quicktime, just won't load on my ipod (nano - most recent)
i am also running the most recent ipod update and itunes update.
i am unchecking decode with quicktime and see if that helps.
ok!
unchecking use quicktime seems to work..
before i had switched encoders to mencoder i guess that makes it not valid on ipod?
there are so many options i don't know exactly what they mean.
thanks for your help.
True, mencoder invalidates the file, as it doesn't add the required metadata (aka "atoms").Originally Posted by djhurlbu
The website documents all six tabs and some how-to guides. Good reading, if you want to know more.Originally Posted by djhurlbu
Try adding the QuickTime codec as described before. The QT architecture just might help with the sync.Originally Posted by djhurlbu
ipod touch 8 gig, new unit only shows a white usb cable/itune .. [RESOLVED]
By vhelp in forum Portable VideoReplies: 1Last Post: 28th Nov 2010, 21:05 -
Fake IPOD Touch mp3/video player needs videos converted..help!
By snafubaby in forum Video ConversionReplies: 13Last Post: 12th Jul 2009, 22:38 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 20:56 -
No sound when converted, going top ipod, using SUPER
By wolfman13 in forum Video ConversionReplies: 1Last Post: 2nd Feb 2009, 10:17 -
Bizzare iPod Behavior with converted MP4 - help!
By cosgrove in forum Portable VideoReplies: 0Last Post: 4th May 2007, 09:08
