Is there a setting in capturing software for aspect ratio? I captured some DV into an avi file using my dvd studio. I have used this program many times capturing 4:3 footage. This time it is widescreen. Where would this setting have been changed? Camera? I couldnt find any setting on the software.
AnonymousGuest
If you mean DV over IEEE-1394, wide is determined in the camcorder before the video is shot. Some cheaper camcorders output letterbox but most output full height, horizontally compressed wide format with a normal transfer if the video was shot wide.Originally Posted by Dr.Gee
Your editing project needs to be set to wide or the imported wide video will revert to letterbox on the timeline.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
The resolution is the same for 4:3 and 16:9 DV footage and it is not uncommon for there to be no A/R flag in the avi (or for editing software to ignore it if there is). Just go ahead edit and make sure you select 16:9 A/R when you encode and it should play back fine.
Buy My Books
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 18:31 -
16:9 Aspect ratio
By jeffh123 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Aug 2011, 20:44 -
Capturing from a DV camera, framerate + aspect ratio issues
By CursedLemon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 1st Sep 2009, 23:12 -
what is aspect ratio?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 3Last Post: 29th Sep 2007, 23:29 -
Aspect ratio
By Digiface in forum Software PlayingReplies: 2Last Post: 24th Aug 2007, 13:35
