For about 2 years I've been making transport stream recordings from my Shaw Cable Motorola DCT64616 III, via firewire and CapDVHS. I then create DVD format directory structure from these .ts files, with SVCD2DVD.
Back around October 2007, I started having various problems with this process, when recording the digital channels. Analogue channels were fine. The current state is:
1. I can record digital channels, high def or regular, on the Motorola DCT64616 III.
2. I can record a transport stream file from the step 1 recording, but there seems degrading in quality: often when there is motion in a scene I notice a coarse horizontal line pattern in that area, similar in appearance to the lines you'd see in an old analogue TV signal.
3. I can play the .ts ok with Media Player Classic. However, if I try to preview it with HDTVtoMPEG2, it doesn't preview or play at all. Older .ts files from the same digital channels and with the same Motorola player preview fine. Similarly in SVCD2DVD, preview of the asset shows nothing. The play progress slider moves left-to-right, but nothing shows.
4. If I follow through in SVCD2DVD and create a dvd from the asset, I consistently get this result:
When playing the output DVD (either test_S2D.mpg or VIDEO_TS.IFO) with Media Player Classic, the audio starts immediately but the video locks, for maybe 2~3 seconds. Then when the video starts there is an obvious out-of-sync delay, and this continues for the remainder of the recording.
I'm sure the issue is with Shaw Cable, and/or the Motorola DCT64616 III, or *something* in my transfer hardware, say the firewire cable. The latter has worked fine in the past, and continues to work fine when doing recording programs on the Motorola DCT64616 III that had been made *prior* to Oct 2007 so: I'm convinced the issue is with my service provider, Shaw Cable. I think something has been altered, either intentionally or inadvertently, that is corrupting my .ts recordings.
In any event: has anyone had similar experience, or have suggestions on how I might resolve this video delay, and/or the coarse horizontal line pattern in moving portions of the image, via some adjustment of SVCD2DVD settings?
Post your SVCD2DVD log file.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Ok, hope I'm doing this right. I opened the file in a text editor and copied the content. And thanks in advance.
Log file content follows:
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.3600.0
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2.57 MB
Executable size in bytes: 2703443
Executable CreationTime: 12/10/2007 1:41:26 AM
Executable LastWriteTime: 12/19/2007 3:50:25 AM
Executable LastAccessTime: 2/6/2008 2:56:50 AM
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 1
Local: 0409
Total Physical Memory: 0.99 GB
Free Physical Memory: 444 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: To Be Filled By O.E.M.
Computer Model: To Be Filled By O.E.M.
System Type: X86-based PC
Computer Name: MENDEL-P4
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 2
User Name: MENDEL-P4\user
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz
Description: x86 Family 15 Model 3 Stepping 4
CPU Speed: 3.192GHz
CPU FSB: 200MHz
L2 Cache Size: 0 bytes
CPU Speed: 3.192GHz
CPU FSB: 200MHz
18:57:35: Logical CPUs: 2
***************************** Time Zone ****************************
Time Zone: (GMT-08:00) Pacific Time (US & Canada)
****************************** VIDEO *******************************
Name: RADEON X700 Series
Processor: RADEON X700 PRO (0x5E4B)
Mode: 1280 x 1024 x 4294967296 colors
Video Ram: 256 MB
Status: OK
Name: RADEON X700 Series Secondary
Mode:
Video Ram: 256 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 175 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 95.8 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 92.8 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 93.7 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<?xml version="1.0" encoding="utf-8"?>
<SVCD2DVD DateTime="2/5/2008 6:57:38 PM" Filename="NONE">
<AssetSet>
<Asset ID="8a3dc297-7945-45b1-89ec-21fd05ff684b" Path="C:\Shaw Cable Box Captures" Filename="test.ts" />
</AssetSet>
<DVDStructure>
<TitleSet Name="New Movie" PostCmd="" MenuButtonType="0">
<MenuButton X1="0" Y1="0" X2="226" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">New Movie</MenuButton>
<Title Name="test.ts" AssetID="8a3dc297-7945-45b1-89ec-21fd05ff684b" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2.5\default.jpg" AudioPath="" />
</DVDStructure>
<Settings>
<General InitialAssetFolder="" InitialDVDFolder="" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" />
<Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
<Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
<Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
<Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
</Settings>
</SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 36.5 MB
file=C:\\Shaw Cable Box Captures\\test.ts
FormatName=mpegts
Num_Frames=1985
DurationInSecs=33
Duration=00:00:33.1
VideoCodec=mpeg2video
VideoFFSTNum=0
Width=1920
Height=1080
Standard=NTSC
BitRate=9258
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x7c1]
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=384
Audio1Channels=6
HDTV2DVDMPG: 9000kbs
Leaving source audio alone.
Pass 1/1: Processing test.ts
18:57:39: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
18:57:39: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
18:57:39: libavutil version: 49.1.0
18:57:39: libavcodec version: 51.27.0
18:57:39: libavformat version: 51.12.1
18:57:39: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
18:57:39: Seems stream 0 codec frame rate differs from container frame rate: 29.97 (30000/1001) -> 59.94 (60000/1001)
18:57:39: Input #0, mpegts, from 'C:\Shaw Cable Box Captures\test.ts':
18:57:39: Duration: 00:00:33.1, start: 8906.759722, bitrate: 9258 kb/s
18:57:39: Stream #0.0[0x7c0]: Video: mpeg2video, yuv420p, 1920x1080, 80000 kb/s, 59.94 fps(r)
18:57:39: Stream #0.1[0x7c1](eng): Audio: ac3, 48000 Hz, 5:1, 384 kb/s
18:57:39: Output #0, dvd, to 'C:\Shaw Cable Box Captures\test_S2D.mpg':
18:57:39: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 9000 kb/s, 29.97 fps(c)
18:57:39: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 384 kb/s
18:57:39: Stream mapping:
18:57:39: Stream #0.0 -> #0.0
18:57:39: Stream #0.1 -> #0.1
18:57:39: Press [q] to stop encoding
18:57:44: [dvd @ 0084E46C]packet too large, ignoring buffer limits to mux it
18:58:14: [mpeg2video @ 00822700]ac-tex damaged at 51 29
18:58:14: [mpeg2video @ 00822700]Warning MVs not available
18:58:14: [mpeg2video @ 00822700]concealing 4679 DC, 4679 AC, 4679 MV errors
18:58:14: video:19069kB audio:1526kB global headers:0kB muxing overhead 19.828161%
18:58:14: HDTV2DVDMPG: done.
18:58:14: Done: Processing assets for DVD creation
Authoring DVD Folders
18:58:14: Creating TitleSet # 1
18:58:14: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
18:58:14: -->: DVDFolders creating VTS
18:58:14: -->: VTS 01
18:58:14:
DVD Folders: Processing C:\Shaw Cable Box Captures\test_S2D.mpg...
18:58:15:
18:58:15:
18:58:15: Finalising DVD...
18:58:15: SVCD2DVD: DVDfolders
18:58:15: -->: DVDFolders creating table of contents
18:58:15: scanning C:\Shaw Cable Box Captures\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
18:58:15: Finalising DVD...Done
18:58:15: Done: Authoring DVD Folders -
Have you tried the created DVD in a stand alone (set top) player? What were the results?
Dwight
- Herm Albright
I haven't tried burning a DVD yet, assuming if it's not playing properly with Media player classic it's not going to improve on a disc. Could give it a try.
I'd grab a RW disc and give it a try - it may play properly and if not, it gives us more to work with.
Dwight
- Herm Albright
LifeView Video III Cable, Looking for Pin Outs or Substitute.
By Computer Nerd Kev in forum Capturing and VCRReplies: 0Last Post: 27th Nov 2011, 06:44 -
Look what I found-a Motorola DCH3200 set-top box for use with Comcast cable
By zoobie in forum DVB / IPTVReplies: 7Last Post: 15th Dec 2010, 21:27 -
Capturing from a Motorola DCT6416 III
By mlong30 in forum Capturing and VCRReplies: 17Last Post: 27th Apr 2009, 21:34 -
transferring video from cable Motorola dvrs to pc?
By Dr.Gee in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2008, 15:23 -
HDTV Cable Card from motorola
By lein in forum DVB / IPTVReplies: 4Last Post: 4th Oct 2007, 16:49
