How can i add VLC player to WMV "Open With" menu?
Results 1 to 15 of 15
Right-click on "filename.ext", select "Open with...",
select "Choose prog/appl". -
Yes i have done that,but i think it only adds program until next reboot... How can i do it with registry? I have tried some things, but without success.Originally Posted by Midzuki
Digiface wrote:
Not at all. If your system does not save that setting into the registry files,Yes i have done that, but i think it only adds program until next reboot...
then it surely has a problem.
As a workaround you can add a shortcut to VLC to your "SendTo" folder. I put one there since VLC would often drop out of my "Open With" if I didn't use it very often. SendTo's great for stuff like that. I even put a shortcut to SendTo into my SendTo folder so I could sendto sendto.
Yes it's already gone after using CCleaner. I think it's about MRU cleaning. I got a MRU cleaner run at the startup also.Originally Posted by Midzuki
Squash: I will try that. Edit. Well actually i have already tried that, but it didn't work. 2Edit: Got that "SendTo" to work. First time i created copy instead of a shortcut. That's why it didn't worked, now it works great.
Check the "always" box.
It seems that, unless you choose a default player for the .WMVs,
the system will not keep an alternative "Open with" list for the file type. -
Here's what you do: go to Folder Options/File Types, find the wmv file type. Click "Advanced", copy the command line that opens wmv's in WMP... create a new action...I called it "Open in VLC"....paste the command line into the box, & replace the directory info with the path to VLC.exe on your machine. Now you can right-click on a wmv file, & one of the choices will be "Open in VLC". I've done this with all the video file types, & it works like a charm.
Stiiv -
Use OpenExpert.
http://www.baxbex.com/downloads.html
I even use it under Vista with no problem.
boyett -
Here is a problem that I have. When I use the open with option and choose GSpot Codec Identification Appliance, the movie opens with GSpot but if GSpot Codec Identification Appliance is not showing and I try an choose GSpot from the choose program option, Windows tells me that the movie that I am trying to open is not a valid Win32 application.
The GSpot that is in the Choose Program dialogue box is not a valid exe file and there is no way that I can get rid of it and force Windows to choose the correct GSpot exe file.
EDIT: Problem solved. Deleted GSpot folder and used regedit to delete all GSpot instances and reinstalled GSpot.
Now GSpot Codec Identification Appliance appears in the choose program box after selecting GSpot exe to open with. No more Win32 errors.
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35 -
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 29th Mar 2012, 23:32 -
Tip: How to add "detele" and "up" buttons in Vista/7
By roma_turok in forum ComputerReplies: 1Last Post: 3rd Jul 2010, 14:54 -
VLC Media Player - "Lost Frames"
By Ancalagon in forum Software PlayingReplies: 3Last Post: 18th Feb 2010, 05:57 -
AVI file "broken" when played with VLC
By Salva Veritate in forum Newbie / General discussionsReplies: 10Last Post: 23rd Sep 2007, 12:01
