Hi, I had a video recording of a concert that was in authored DVD format, but missing the menu .VOB. Thanks to some advice from forum members yesterday, I used VOB2MPG to get an MPEG, and I used GUI for dvdauthor to make menus and re-author the disc. My author log showed a number of errors. It gave this trio of warnings numerous times during the author process:
WARN: Audio pts for channel 0 moves backwards by 1440; please remultiplex input.
WARN: Previous sector: 18.772 - 18.836
WARN: Current sector: 18.820 - 18.884
And it gave the the following at the end of the log:
INFO: Video pts = 0.176 .. 0.209
INFO: Audio[32] pts = 0.176 .. 0.176
STAT: VOBU 3 at 0MB, 3 PGCS
INFO: Generating VMGM with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: ntsc
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
ERR: That form of jumping is not allowed
STAT: fixed 3 VOBUS
ERR: in VMGM pgc 1, button MM1B36
When I opened it with VLC through GUI for dvdauthor, it gave me the following error message:
Unable to open 'C:\Documents and Settings\xxxxx\My Documents\GFDOutDir\DVD\VIDEO_TS/VIDEO_TS.IFO'
Then it briefly flashed on the one of the submenus and began to play the movie itself. Does anybody have any idea what happened?
Usually this error is due to a jump from the main menu directly to a chapter (which is not allowed by the DVD spec). There are several possibilities to circumvent this limit. If you want help, please post (or send me by mail) the saved project file and the created author.xml file. Compress the files as zip, rar or similar.ERR: That form of jumping is not allowedGUI for dvdauthor:
https://www.videohelp.com/~gfd/
Which to use, DVDAuthorgui or "GUI for dvdauthor" ? Or DVDauthor in batch ?
By halsboss in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 11:00 -
GUI for dvdauthor problems – Strange menu sequence behavior using Henc
By jsbullock in forum Authoring (DVD)Replies: 9Last Post: 20th Feb 2009, 02:44 -
GUI for DVDauthor and Vista?
By Robert Simandl in forum Authoring (DVD)Replies: 18Last Post: 8th Apr 2008, 06:53 -
GUI for DVDAuthor
By netbuddy in forum Authoring (DVD)Replies: 35Last Post: 15th Nov 2007, 05:12 -
gui for dvdauthor HELP
By dontpanic in forum Authoring (DVD)Replies: 10Last Post: 4th Aug 2007, 06:47
