Hi,
In my eternal quest for a reliable capture software that would allow me to capture full length movies without losing A/V sync, I now tested VirtualDUb 1.4.8.
It seems to do a great job, allowing me to capture 704x576 MJPEG AVI without any dropped frame, to a 10GB file without any AV sync problem.
So I decided to leave it running for a full 1h40 movie.
Surprise when I came back : Blue screen on Win2K, had to reboot. I had a 22GB AVI file that no software could read.
Did anybody here experienced this before ? Can someone advice on what to do to avoid this ?
My setup is : Celeron 566@850, mobo Asus p3V4X, latest via 4in1 drivers (4.37 I think), ATI AIW 128Pro AGP, sblive 1024, Win2K Pro sp1, Budweiser x12, cadbury cookies.
thanks for helping
Waldok 8)
Personally I think the Bud would cause this kind of fault...
I think I'd probably upgrade to SP2 and try again. Worth a go..
Also, how are your temps ?? Your pretty seriously O/C'd there...
As a general platform stability test you could try running http://setiathome.ssl.berkeley.edu/ for a few days. It usually shows up a platform that is running on the limits..
pass the cookies..
:P
Col -
@Wonderin : he he Bud is just fine. That's the only piece of my equipment I wouldn't suspect nor change :P
@bigcolinP : no prob with temps, I made myself a custom case, full of vents and holes. I ran all possible cpu-intensive progs and I never go past 21°C in the case and 36°C (Celsius degrees, can't convert to Fahrenheit) on processor. It works like a charm and I'm more than happy I gave this overclocking thing a try
I'll give SP2 a try though.
Reliable USB capture devices?
By slats7 in forum Capturing and VCRReplies: 21Last Post: 11th Mar 2012, 19:32 -
Need Reliable MPEG-2 Editing Software ...
By cyberboy in forum EditingReplies: 2Last Post: 15th Nov 2008, 01:04 -
capture scene length info
By rhymejerky in forum Authoring (DVD)Replies: 1Last Post: 22nd Mar 2008, 15:33 -
Reliable Company to provide cables for a Long Cable Run
By xixzer0xix in forum DVB / IPTVReplies: 6Last Post: 16th Nov 2007, 17:45 -
Any free, good, reliable software for video streaming capture?
By rob1974 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2007, 15:26
