Hey! Does anyone know of a quick way to convert .avi to MPEG-2 for play on standalone DVD players?
I use Total Video Converter. It has a lot of nice options, but when converting from .avi to MPEG-2, it's slower than dirt on molasses. An .avi that's about 1 hr and 30 min, takes about 1 hr and 30 min to convert (pretty much real time conversion). Plus the time to burn, so about 2 hours.
I've tried some other conversion programs, and they are aren't any faster.
Maybe I'm missing a problem that's out there that is good and fast? Any ideas?
Thanks!!!!
I think if you want to go any faster than real time (aside from going dual or quad core cpus) is to get a avi compatible dvd player. They are dirt cheap these days and you can just burn as data so no conversion needed as long as the player handles the codec.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I second the standalone player route. It will save you time, money, and prevent further quality loss.
Google is your Friend -
Agree with just getting another player, BUT you need to realize that any of the following may or may not prevent playback of AVI files on DVD players that support Divx/Xvid:
1) GMC (Global Motion Compensation) - best to avoid it, but if you have only 1 warp point it MIGHT work. It will surely fail with 3 warp points.
2) QPel (Quarter pixel)
3) Resolutions greater than 720x576
4) Packed bitstream
5) Video bit rates above 2000 Kbps
6) Use of any audio other than CBR MP3. Use of VBR MP3, DTS and even AC3 may cause playback problems unless the video bitrate is reduced, perhaps even as low as 1400 Kbps.
Fast conversion = bad quality
Slow conversion = good quality
Either get a faster PC or let your encodes run while you sleep so you don't care how long they take. -
Yes, around real time AVI to DVD here too, on my single core 3.2 GHz. Not that I do them any more, as my player plays AVI fine.
/Mats -
I agree that a dvd player that plays avi's is the best solution. But if you must convert than try convertx2dvd. It's faster than Total. Winavi is even faster. The Philips player will play almost all avi variations, plus they now have a usb port that can be used to play avi's (divx, etc.). I use it all the time. Works great.
With the new V3 of ConvertXtoDVD, I got between 190 and 210fps encoding speed! Of course, that was on an 8 Core 3.0Ghz machine.
MPEG-2 528x576 to AVI conversion problem.
By madman1987 in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:53 -
Sound lost after conversion mpeg to avi
By maclinux in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 13:47 -
Problems with mpeg after conversion, or with original avi - help
By krisbee in forum LinuxReplies: 1Last Post: 30th Oct 2007, 16:56 -
No sound conversion MPEG-TS to .avi
By oli60 in forum ffmpegX general discussionReplies: 2Last Post: 22nd Oct 2007, 00:49
