Hi everyone.
First time poster and I'm hoping you might be able to help me out with a ripping problem.
A friend of mine recorded a few shows onto a DVD-r for me.
One is in EP mode and the others are all in SLP mode.
I want to rip the disc and re-author it with a custom menu via TMPGEnc.
The problem is, that when I try and rip the disc using DVD Decrypter or DVDFab, the resulting files won't open up in TMPGEnc or any other program I've tried.
I used DVDFab to rip the EP show on its own, and and it played on my HD via WinMP with no problems, but I can't rip the SLP files no matter what I try. They only work when I use PowerDVD, a standalone DVD etc but no ripping success.
Is there a way to rip SLP files? Is it a secret art!
Thanks for reading my problem and I hope someone will be able to help.
Stefi
	are they in standard dvd-video (vob,ifo,bup) mode? or some other format on the disc?
	Yep.
 One standard VIDEO_TS folder with all the usual stuff and another called VIDEO_RM.
 The dvd name is defined as DVD_VR.
 ...do you have a cunning plan?
	I can't believe I didn't think of that before!
 I've just tried it and it will accept the EP file on its own or the SLP files.
 If I try and add both, it tells me they are in the wrong format.
 If I rip the SLP & EP files into separate folders, will I then be able to combine them into one DVD at a later stage?
	Quick update.
 I've managed to combine all the shows via TMPGEnc Author 3.0
 Thanks Baldrick.
 It's the simple things that we sometimes overlook!
 Stefi
	If you create a separate track for the ep and slp it should work fine to combine different formats on a dvd. Or you have probably already discovered it.
  Rip DVD titles to MPG files?By Asterra in forum Newbie / General discussionsReplies: 4Last Post: 25th Dec 2011, 06:09
  Old VHS Tapes Have No Picture Recorded at LP and SLP SpeedBy Hypnotised16 in forum MediaReplies: 14Last Post: 17th Mar 2010, 16:09
  SLP has gone bonkers but SP fine on VHS/DVD PLAYER.By spicy83 in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 00:13
  What happens if you rip a dvd without BUP files?By HmNtr in forum DVD RippingReplies: 12Last Post: 10th Nov 2008, 19:06
  Cleaning up video from SLP recordingBy buddycat in forum Video ConversionReplies: 3Last Post: 12th Oct 2008, 04:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
