Hi,
I have a question, when I play my original DVD movie on Media Player Classic, the movie resolution(720x480) display(width) almost fit on my 17" monitor. But after I convert it to XVID(720x480) using AVI.Net and playback on MPC, the width of the movie is quite smaller compare to DVD.
If I open photoshop and create a picture of 720x480, it give me the same resolution as the XVID.
Can anybody tell me why is this?
thanks.
The dvd is resized to 4:3 or 16:9 while the avi xvid is probably not resized. You need to read about aspect ratios, see http://www.doom9.org/aspectratios.htm
What is the aspect ratio of the source dvd? 4:3 or 16:9 ? Then I would resize to a 4:3 or 16:9 resolution instead of making 4:3 or 16:9 avi xvid as MOST players ignore the display aspect ratio. See https://www.videohelp.com/guides/determining-aspect-ratios-and-resolutions-id360#360 -
My source is 4.3 according to the back of my dvd case. The movie I play have a black border on top/bottom.Originally Posted by Baldrick
So according to your first link, I must put a re-size my video to (480*4/3= 640) output 640x480 ? Is this right? why the resolution for 4.3 is smaller compare to 16.9 (480*16/9=853) output 853x480?
MPC upscaling DVD? -
Square pixels versus non square pixels.
You can save yourself more space by cropping off the black bars as well. They aren't needed.
If you wanted to maintain the 720 width, you could resize to 720 x 540, however resizing up usually reduces quality more than resizing down.Read my blog here.
Usually when I convert my dvd to avi in AVI.net, when I select 720wide, it always auto give me the high and it always smaller then 480or576. If I force to select 480 or 576 then my video going to stretch.Originally Posted by guns1inger
Is there anyway that I can convert my dvd to avi 720x480 or 720x576 and the video doesn't stretch? Or it can't be done?
thanksss
Why Is A 720x480 DVD Played As 853x480?
By czgirb in forum Newbie / General discussionsReplies: 4Last Post: 20th Jun 2011, 04:07 -
standard 720x480 DVD to Avi 720P with free converter?
By MilesAhead in forum Video ConversionReplies: 26Last Post: 26th Apr 2010, 18:44 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 20:15 -
VHS to DVD resize 640x480 or 720x480
By opti280 in forum Authoring (DVD)Replies: 2Last Post: 26th Feb 2008, 19:43 -
Ripping DVD to avi 720x480 using FairUse2?
By suneo in forum Video ConversionReplies: 11Last Post: 28th Oct 2007, 08:11
