Several years ago I did some VHS capturing using VirtualDub 1.5.2 which worked well. Recently I was asked to bring it out of storage and again capture some old VHS tapes and it worked fine ... just as I remembered. But then I noticed that VirtualDub 1.7.7 was available so I downloaded and attempted to use the latest version ... and it failed. Under "Video Sources" all selections are greyed out and not available. However it still works fine with Ver 1.5.2. I don't see any settings that might remedy that? Any ideas?? I appreciate any input.
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
Look under Device. does it show your card? does it have a checkmark next to it? directshow or VFW?
GideonK,
I don't see an entry called "Device" in VirtualDub and I've checked each item in the drop down menus. Where should I look? It works in 1.5.2 and fails in 1.7.7. My card is an Nvidia VIVO and the driver version is 1.08 which is the only driver that works. Any other driver causes a white band to appear through my captures."No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776 -
File > Capture and then you should see device in top, betwwen File and Video
Duhhhhhh ..... I guess I need to head back to school!! :^)) Thanks GideonK and Sally to you both. I guess my confusion was that "Device" is not visible on 1.5.2 so I'm thinking that it somehow got corrupted. It must have been available at one time ... maybe when I first started using it. And "Device" is also not INITIALLY visible on 1.7.7. Device ONLY shows up at the top menu on 1.7.7 AFTER you select File>Capture. I selected VFW and all seems ok. I do appreciate both your responses ...
VirtualVCR cap fails in virtualdub...
By Asesinato in forum Capturing and VCRReplies: 36Last Post: 12th Apr 2012, 12:43 -
AVI to DV fails after one.
By bmccall17 in forum ffmpegX general discussionReplies: 3Last Post: 15th Jun 2009, 12:49 -
mencoder fails
By scruss1 in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 23:48 -
avi: alright with mediaplayer, virtualdub fails
By engel in forum Software PlayingReplies: 14Last Post: 11th Aug 2008, 04:59 -
Burning always fails at 98%...
By Variable in forum DVD & Blu-ray WritersReplies: 14Last Post: 29th Feb 2008, 16:45
