    Jun 2007
    Ireland
    hello,
    Ive just downloaded backup hddvd GUI_0.5,im not familier with the whole hd decrypting! I am unable to use the program.
    When i try to use the program i put my disk in the drive (doom) select the location of the drive select destination of the output,
    i entered the key that was supplied for doom movie but the hash key is not the same as on the disc i press start rip, it says look for movie key, then it says not implemented,and the button i selected to start the rip now says "stop rip" then "start rip" again and this is all two seconds later.
    i see it requires keys and a hash keys....i didnt even know this till i opened the program,anyway the program comes with some keys already,but it doesnt have my movies in it which are transformers and doom,it does have a "doom" selection but the hash key isnt the same and it wont decrypt i assume this is why.
    I would be greatful if some one could give me a brief explaination on how to use this program properly and go about getting the keys required to decrypt the discs also the difference between title keys and volume keys,
    also within the Backuphddvd folder i downloaded there are other files =
    aca_decrypter,
    backuphddvd (C# port)
    It could well be i cant use the program because im supposed to do somthing with these files.
    i have cyberlink powerdvd player software installed and an LG hddvd/bd rw drive.
    Hope u can help
    Thanks.
    Use dvdfab decrypter or anydvd instead. They both support hddvds.
