Hi,
I need to connect my lap top (dell 2nd hand so no XP disc) to my pc in order to transfer files from lt to pc. How do I do this?
Cheers
Bill
Results 1 to 9 of 9
Needs more specifics
There are a few ways of transfering data between systems
A: Basic network
B: Flash drive / external hard drive
C: cd/dvd (depending on availability of burner) (I use a usb external)
D: A drive adapter (to connect laptop drive to pc system) (some disassembly required)
You choose which is the most applicable and easiest method -
Also, PC to PC USB transfer cable, like this:
http://www.geeks.com/details.asp?invtid=BLU-USB20-DL&cat=CBL&cpc=CBLbsc
It assumes that you have functional USB ports, perferably 2.0. I have used it with 1.1 ports but we are talking a long transfer time them.
Hope this helps!
Occasional use, for files up to 1 or so GB, a USB thumb drive is convenient. If you're doing it regularly, you should do it via the network -- ethernet cable or Wifi, takes bit longer to set up, but then is painless.
Hi All,
Cheers for the replies.
I've tried ethernet cable and to set up a basic network, but the 2nd hand lt doesn't have XP disc, and the pc doesn't seem to find the lt.
I'll give the usb cable ago when I can get my hands on one.
Cheers again.
Bill -
To be honest, I have no idea what you are trying to say with that sentence, however if you are trying to connect two PCs directly with ethernet you may need to use a crossover cable, not a standard ethernet cable. These are wired differently to a standard cable.Originally Posted by LabanBRead my blog here.
Hi GS,
I've tried to use the ethernet cable which connects me to the internet between the two computers. The main computer, pc, seems unable to find the lt.
Again, I think I'll try the usb cable when I can.
Cheers
Bill -
As guns1inger mentioned there are different types of ethernet cables. The ones that hook a computer to a broadband modem are patch cables (generally). In order to hook up a pc to pc through lan cables without a router you need a "crossover" cable. As mentioned previously they are wired differently so they can talk to each other without a router.
Lap top audio doe not work
By romanstopme in forum ComputerReplies: 2Last Post: 8th Nov 2008, 14:43 -
Having laptop on your lap
By Tbag in forum ComputerReplies: 8Last Post: 28th Sep 2008, 21:04 -
Lap Top & Internet Question
By DuBsTaR in forum ComputerReplies: 5Last Post: 10th Mar 2008, 19:34 -
dvd +r made on lighton 5001 can't be read on desktop or lap top
By skydiverbill in forum DVD & Blu-ray RecordersReplies: 6Last Post: 27th Jan 2008, 15:02 -
Can't play dvd on my lap top!
By BSarte in forum Software PlayingReplies: 2Last Post: 16th Sep 2007, 08:43
