I used FAVC for the first time last week. I successfully converted 720p.hdtv.x264 1.7gb .mkv video file to DVD format choosing 'quality' in the optimized presets, was very pleased with the result.
What I was planning on doing was to convert a single video to a DVD+RW and the rewriting over it with a new one each week. Anyway.. FAVC doesn't want to work for me on my second single .mkv video file that I'd like to convert. It is exactly the same specifications 720p.hdtv.x264 1.7gb.
The first single file conversion worked fine
VIDEO_TS folder:
VIDEO_TS (.vob)
VIDEO_TS ifo file
VIDEO_TS.bup
VTS_01_0.BUP
VTS_01_0 ifo file
VTS_01_1 (.vob)
VTS_01_2 (.vob)
VTS_01_3 (.vob)
And the one that won't only contains:
VIDEO_TS (.vob)
VTS_01_1 (.vob)
VTS_01_2 (.vob)
VTS_01_3 (.vob)
I do get [liba52 @ 02241000]Error decoding frame during the Video Analysis stage.
I have retried several times and even redone the first one just to check and it doesn't give the Error decoding frame message on the first one.Code:********************************************************* ******************* Analysing Video 0 ******************* ********************************************************* AVS2AVI v1.39 (c) 2002-2004: Christophe Paris, David Leatherdale, int21h, Moitah http://www.avs2avi.org/ [matroska @ 0218D018]Ignoring seekhead entry for ID=0x1549a966 [matroska @ 0218D018]Ignoring seekhead entry for ID=0x1654ae6b [matroska @ 0218D018]Ignoring seekhead entry for ID=0x114d9b74 [matroska @ 0218D018]Unknown entry 0x73a4 in info header [matroska @ 0218D018]Unknown track header entry 0x55aa - ignoring [matroska @ 0218D018]Unknown track header entry 0x23314f - ignoring [matroska @ 0218D018]Unknown track header entry 0x55ee - ignoring [matroska @ 0218D018]Unknown track header entry 0xaa - ignoring [matroska @ 0218D018]Unknown track header entry 0x55aa - ignoring [matroska @ 0218D018]Unknown track header entry 0x23314f - ignoring [matroska @ 0218D018]Unknown track header entry 0x55ee - ignoring [matroska @ 0218D018]Unknown track header entry 0xaa - ignoring [liba52 @ 02241000]Error decoding frame Source: * Filename: "C:\Documents and Settings\Brent\My Documents\Working Folder 0\Tit le0Info.avs" * FourCC: YV12 * Frames: 250 * Resolution: 1280x720 * Frame rate: 0.100 FPS Compressor: * No Recompression Destination: * Format: Null [matroska @ 0218D018]Ignoring seekhead entry for ID=0x1549a966 [matroska @ 0218D018]Ignoring seekhead entry for ID=0x1654ae6b [matroska @ 0218D018]Ignoring seekhead entry for ID=0x114d9b74 [matroska @ 0218D018]Unknown entry 0x73a4 in info header [matroska @ 0218D018]Unknown track header entry 0x55aa - ignoring [matroska @ 0218D018]Unknown track header entry 0x23314f - ignoring [matroska @ 0218D018]Unknown track header entry 0x55ee - ignoring [matroska @ 0218D018]Unknown track header entry 0xaa - ignoring [matroska @ 0218D018]Unknown track header entry 0x55aa - ignoring [matroska @ 0218D018]Unknown track header entry 0x23314f - ignoring [matroska @ 0218D018]Unknown track header entry 0x55ee - ignoring [matroska @ 0218D018]Unknown track header entry 0xaa - ignoring * Pass 1/1: Frame 163/250, 214.89 MB, 3.09 FPS, ETA 00:00:28
I don't understand, the 2 video files are no different from one another.
I could cry.
Results 1 to 15 of 15
The conversion is there, I can view parts of it by opening VTS_01_1, VTS_01_2, VTS_01_3 in a media player. What can be done to get this into a playable DVD? Preferably with a background/menu.
Thank you in advance. -
Import into TMPGenc DVD Author?
/Mats -
Right, as I am not familiar with this software what are the steps I need to take to link them together and not to alter the quality of the conversion?
You just load them into the same title in TDA (one after the other), and remove the chapter points that TDA inserts at the joins, and it should play back as one continous video.
/Mats -
It seems pretty straight forward but I'd like to ensure I'm not touching or changing the conversion at all. If you could quickly run through the motions that would be brilliant.
No, it wont touch your video. If you have TDA 1 (or 2?) it even can't touch the video, as it has no video encoding capabilities. TDA3 can encode video, but still shouldn't touch it if the source material is DVD compliant, like yours is.
/Mats -
Good good. I am trialing version 3.
I add the 3 "clips" (VTS_01_1, VTS_01_2, VTS_01_3) into a single track but they act like chapters, so when I click 'next chapter' it flicks through the 3 clips. I don't want that, just 5 min jumps.
Sorry to be such a pain, I'm a newbie. -
I'm not sure which button to click - I only have TDA 1.6, and not where I am right now - maybe someone with TDA3 can help out?
/Mats -
Alright, well thanks for the help guys. At least I can get my conversion on DVD now. That's the main thing.
I just tried to convert another video, same specifications again, now this time FAVC did not generate a full DVD again.
Does anyone have any explanation for this? Quite frustrating as it takes around 3-4 hours to convert so it's not something I can quickly retry.
DVDslideshowGUI stopped creating VIDEO_TS. IFO & BUP files
By gobettee in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2012, 15:52 -
FAVC Video_TS EMPTY! (have working files?)
By RobAdam in forum Newbie / General discussionsReplies: 34Last Post: 11th Jun 2011, 14:28 -
How do I convert VIDEO_TS containing VOB, BUP, IFO files to a single file
By Firesmith in forum Newbie / General discussionsReplies: 1Last Post: 28th Jul 2010, 12:14 -
VOB2MPG - VIDEO_TS AND VTS_01_0 aspect ratio problem
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 21st May 2010, 08:28 -
Missing VIDEO_TS.VOB and all VTS_xx_0.VOB
By PietjePuk314 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 18:44
