Ripped DVDs on my pc are playing BLOCKY. anyone know what i need to do to fix that?
thanks
Results 1 to 10 of 10
I play them with Power DVD or Media player. Rip them with DVD shrink.
It happens with downloded DVDs too. I wonder if its a codex problem? -
Try playing one with VLC Media Player. It uses it's own codecs, so it's one way to test if you have a codec problem.
Do un-ripped DVDs play blocky as well? You didn't specifically say whether you had identical problems with the original DVDs before ripping them.
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
It plays perfect with VLC Media Player. SO i guess its a codec problem....right?
Probably. Are you playing with windows media player or some other player?
what mpeg2 dvd decoder are you using? With Windows XP Video Decoder Checkup Utility http://www.microsoft.com/downloads/details.aspx?FamilyId=DE1491AC-0AB6-4990-943D-627E6...displaylang=en can you check what you have and also change the default decoder that is used in windows media player.
ripped dvds when converted to avi out of sync
By angryassdrummer in forum Video ConversionReplies: 3Last Post: 9th Jan 2012, 06:43 -
No sound on ripped dvds
By PaulaAlmeida in forum Video ConversionReplies: 18Last Post: 23rd Jan 2011, 05:19 -
How can new Sony DVDs be ripped?
By mythblstr in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2008, 18:42 -
How do you play your ripped DVDs?
By andy99 in forum Software PlayingReplies: 12Last Post: 6th Dec 2007, 01:39 -
ripped dvds @ wmp
By slimselecta in forum Newbie / General discussionsReplies: 7Last Post: 18th Nov 2007, 09:05
