Hey all
I have a bit of a problem. I recently got some videos of this old cartoon show I watched as a kid (The angry Beavers). These episodes are broken in half, because each episode come with two mini episodes.They seem to be in avi format but virtualdub doesn't let me import them in.
So I was wondering, how could I convert these episodes with SUPER video converter, so virtualdub can recognize them, and then I can append each mini episode to from one whole episode. Your help is appreciated greatly.
What settings do I use with SUPER, if I can use this software for this job.
P.S Most episodes are in the same resolution and frame rate, but some aren't. Thats why I would have to convert them, so I can later append them.
Results 1 to 13 of 13
Have you dropped one of those episodes into Gspot to see what video and audio formats it's using? Let us know what you find or post a screen shot from Gspot. That would help considerably to give us an idea what program to use for conversion. You can mask the titles.
VD can also open more formats when used with a frameserver. SUPER isn't a very good converter at times, but it is able to use different formats.
Also what format do you want to end up with? I'm guessing DVD. If so, I would try to encode them once directly to MPEG-2. -
H.264 with MP3 audio. You should still be able to get that to MPEG with one encode. It has CBR MP3, so hopefully no sync problems. Of course, it's in PAL format.
You might try ConvertXToDVD or maybe the freeware FAVC.
More info about the format: http://en.wikipedia.org/wiki/H.264 -
To open those files in VirtualDub you will need a VFW based h.264 decoder. ffdshow includes one.
Well I would like to end up with an mpeg2 so I can later convert to ipod or psp etc... I'm not planning on burning these to a DVD. Jagabo if I install ffdshow will virtualdub then open my files.
I was going to say the same thing
I find AviDemux to be very useful for cutting, appending, and/or getting a quick mpeg from AVI
I use super a lot, but mostly in a different context
I have found it very useful, when i want to reduce the frame rate,
which is something I do when creating GIFS or swf files for my phone
I use super to create the 7.5 fps avi, that I import into the programs for making the GIFS or SWF files
a couple of examples
http://img107.mytextgraphics.com/photolava/2008/01/22/sg1gate-4996rjw5r.gif
http://img107.mytextgraphics.com/photolava/2008/01/22/stargate11-499fs55c5.gif
heres the link to swf file i made for the touch screen of my voyager
http://www.sendspace.com/file/99pynl
sorry for getting OFF topic -
hmm sounds good. How do append with this program. I just cant find the feature.
Used Super to convert RMVB but got no audio
By LWC in forum Video ConversionReplies: 1Last Post: 12th Jan 2009, 15:17 -
Joining 33 avi files with vdub
By aruwin in forum EditingReplies: 3Last Post: 9th Oct 2008, 03:30 -
Convert MP4 to WMV using SUPER
By bdr13278 in forum Video ConversionReplies: 6Last Post: 21st Aug 2008, 12:19 -
Joining AVIs - Vdub reports audio streams do not share common sample rate
By Lolipop Jones in forum Video ConversionReplies: 3Last Post: 22nd Jan 2008, 14:32 -
Super 8 film convert to cd
By joe8915 in forum Newbie / General discussionsReplies: 6Last Post: 5th Jan 2008, 07:52
