Hi, I downloaded a video recording of a concert, and it was supposedly an authored DVD. But when I tried to make an image using ImgTool, it gave me an error. Upon closer inspection I found that a file appears to be missing. These are the contents of the VIDEO_TS directory:
VIDEO_TS.BUP
VIDEO_TS.IFO
VIDEO_TS.VOB
VTS_01_0.IFO
VTS_01_0.BUP
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
VTS_01_4.VOB
The folder is missing VTS_01_0.VOB, but it does have the .BUP and .IFO files. If I am not mistaken, the missing file should be the menu. Does anybody know how I can solve this problem and get it burned to a DVD? Someone on the forum where I got this said he was able to burn it using Divx, but that's lossy and I'd like to avoid that.
I can think of several options. You could extract the MPEG from the VOB files with VOB2MPG and reauthor it with the freeware GUI for dvd author, and add a new menu if that's what's missing. You could also play back the VOBs with a player like VLC and see what you do have. Extracting the MPEG or reauthoring won't change the quality.
Exactly.Originally Posted by redwudz
Just start at VTS_01_1.VOB -
Menus are made with the authoring program. You can use graphics programs if you want specific photo type menus. The choices are fairly well unlimited. Look to our 'Author' guides to the left. But most any authoring program will create simple menus.
Missing VOB
By 5ZVP in forum DVD RippingReplies: 5Last Post: 20th Jul 2011, 21:03 -
Audio missing in VOB file
By marknyc5 in forum DVD RippingReplies: 3Last Post: 20th Jul 2008, 19:48 -
VOB Files Missing or Not?
By Spetznaz24 in forum Newbie / General discussionsReplies: 10Last Post: 14th Apr 2008, 17:36 -
Missing VIDEO_TS.VOB and all VTS_xx_0.VOB
By PietjePuk314 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 17:44 -
vob files now missing
By flyingrrt in forum DVD RippingReplies: 2Last Post: 20th Dec 2007, 12:35
