ok, I have been using vdubmod to blur stuff out. but is there anyway, I can just blur out like 5 secs of a movie not the hole thing. Like if someone was naked lol or something like that?
Results 1 to 9 of 9
use the Conditional filter from Dmitri Schamschufko. It allows you apply almost any filter to a specified frame range.
Buy My Books -
The Conditional Execution Filter seemed to have disappeared.
It allowed you to use different filters for different parts of a video. Without that, you can cut out a part of the video you want to handle differently in Direct stream copy mode, open it in a second VirtualDub, apply your filters, then save it out in the same format as the original in Full processing mode, then add it back into your first VD file.
Or learn some AviSynth so you can use the Trim or ApplyRange filters to filter only parts of a video:
http://avisynth.org/mediawiki/Trim
http://avisynth.org/mediawiki/Animate -
Originally Posted by manono
I don't need to learn how to do it that bad. Just wanted to know just in case i ever needed to do it and u can never know to much. -
Buy My Books -
You can get it from the Wayback archive:Originally Posted by redwudz
http://web.archive.org/web/20050405002942/http://wwwtcs.inf.tu-dresden.de/~dc1/conditional/
That has Version 0.5b - March 2003, which appears to be the last version.
It works in VDubMod 1.5.10 (the latest, I think).
Blur
By jfreak53 in forum EditingReplies: 3Last Post: 24th Apr 2010, 15:22 -
Unwanted blur when rendering
By Notuom in forum EditingReplies: 16Last Post: 11th May 2009, 18:25 -
can HD or Blur Ray be recorded?
By Ade007 in forum DVD RippingReplies: 4Last Post: 11th Feb 2008, 18:22 -
motion blur on tv
By ineedhelp007 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2007, 10:49 -
> Interlaced and motion blur <
By Dark Alpha in forum Newbie / General discussionsReplies: 53Last Post: 12th May 2007, 16:08
