I got this component cable at Wallmart but I see that the pichture is worse than in analog red-yellow -white...
Results 31 to 36 of 36
TV and DVD player model numbers?Originally Posted by 1234567Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Tv -- Samsung LCD full HDOriginally Posted by edDV
DVD -- player Philips DVD recorder -
Model numbersOriginally Posted by 1234567
About a page ago I suspected you are faking this.Recommends: Kiva.org - Loans that change lives.
These are the cables I use and they can easily carry up to 1080p .
and they don't cost an arm and a leg, also if you have a regular av cable (red,white and yellow) you can use that as well since it is the same as the colored red green and blue , as long as you follow the colors you will be fine .
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023501&p_id=...seq=1&format=2 -
Tv -- Samsung LCD full HD LNT 4661Originally Posted by edDV
DVD -- player Philips DVD recorder DVDR3455H
p.s. I used the original AV( red-yellow-white) cables from Samsung VCR, and the quality of pichture is much better when I use component cables that I got yesterday. Is better to turn them back at Wallmart, because I do not see upgrades of the pichture
how do i edit menu connections on an existing dvd?
By animalia in forum DVD RippingReplies: 7Last Post: 14th Jun 2010, 04:42 -
Question about transferring HD-DVR to DVD connections
By kevin75 in forum DVB / IPTVReplies: 1Last Post: 29th Apr 2008, 13:03 -
DVD Lab - Movie/Title order in connections view
By BeachNut in forum Authoring (DVD)Replies: 5Last Post: 21st Jan 2008, 17:17 -
VHS to DVD: what connections to use?
By Stabes in forum Newbie / General discussionsReplies: 7Last Post: 14th Jan 2008, 01:05 -
HD connections?
By James in HD in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 13th Nov 2007, 18:02
