There is an MPG file that when I open it in Gspot, the Aud button does not render, and the Vid button does not render. If I hit the MS A/V, the audio and video play fine. Why does the M/S render when Aud and Vid do not?
Each time I have used Gspot to try to diagnose a problem, it always shows the audio and video codecs as being installed, yet there is a problem, or I would not be trying to troubleshoot. Why does Gspot show codecs as being installed yet there is a problem with audio or video playback?
How can I better learn to use Gspot? I tried AVIcodec. When I loaded the file that I am trying to play (MPEG2 with 48Khz LPCM audio), it reported that LPCM is not yet supported. Huh?
Understand that the MPG file at issue (now) plays, even though there is some tearing and some random pixelization on the right side of the screen that is not present when I play the file on another computer. The problem computer reports using the CyberLink Video/SP Decoder (PDVD7) while the good computer reports using AverMedia MPEG Decoder. Is it possible to install the Avermedia codec on the problem machine without installing Avermedia? How?
To use the AverMedia codec, you would need to install that software. Although there shouldn't be any issues with the codec currently used, it is generally one of the best. There are also several other codecs that you could use, just take a look in the Tools - Codecs section.
Otherwise, it just sounds like a typical codec issue. To troubleshoot, install a player such as VLC which uses it's own codecs.Google is your Friend -
This might work: use a program like codec sniper to determine which file is the AverMedia codec. It will likely be in the \Windows\System32 folder. Copy the file to the other computer and register it with RegSvr32.exe.
Need help understanding pros and cons of different codecs
By shira in forum Video ConversionReplies: 4Last Post: 5th May 2010, 04:41 -
Stream type mismatch - 19023 with DVDit Pro 6 Redux
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2010, 18:24 -
VRO to VOB Redux
By sambat in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2009, 18:20 -
Pet Peeve - Movie Redux
By rkr1958 in forum Newbie / General discussionsReplies: 11Last Post: 19th Nov 2008, 08:37 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29
