This is very odd and it just started happening for no reason. I installed some video editing software when I noticed it (which I have repeatedly uninstalled/reinstalled). All videos play fine in VLC but I really want to play mpeg videos in Vista Media Center. I have literally tried everything, from reinstalling ffdshow, xvid, divx, codec packs etc. I used gspot and get the codec put it doesn't seems to be installing properly. As I said everything played fine and now codecs don't register at all.
Any help would be greatly appreciated.
"codec packs" made it worse. Uninstall them all, maybe manually remove some (Muxman, I believe), and then CCleaner the system registry.
Too many codecs is worse than having none.Want my help? Ask here! (not via PM!)
I uninstalled anything that I found which was a codec checker, xvid and ffdshow. Used CCleaner to clean registry, rebooted, reinstalled xvid, tried to play an xvid file, not playing, doesn't recognise file type in WMP 11 Vista.
Update: Ok, I think im on to something. I got them working in MPC when I switched the mpeg file associations from DirectShow to RealMedia. Is there anyway to wither reinstall directshow or chnage them in WMP?
Lagarith won't play in MPC or WMP
By mst in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2012, 18:29 -
WMP/WMC won't play Subtitled MKV's, MPC will?
By Rantlers in forum Blu-ray RippingReplies: 1Last Post: 28th Apr 2010, 05:54 -
Samsung HD video won't play in VLC, but will in Win 7 WMP... why?
By wild_fan in forum Software PlayingReplies: 3Last Post: 18th Dec 2009, 12:33 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 21:41 -
x264 audio won't play in GB-PVR or WMP, works fine in MPC
By bigshotceo in forum Software PlayingReplies: 2Last Post: 15th Apr 2008, 09:55
