Hi all,
I running XP Pro SP2, Prescott with 3.0Ghz, 512 RAM 400 Mhz Kingston
Both DOS memtest and Windows memtest were showing RAM errors - so I thought perhaps it was my BIOS/CMOS settings - so I changed the memory settings from Auto (based on SPD) to "Ultra" - 400 mHz
Now, I can't even post - and my monitor shows nothing - I tried changing monitors - no difference - I tried booting from a floppy - no screen info . . .
So I am wondering what I did to my system - [I don't know what SPD or Ultra are] and how can I fix it - so I can at least boot and hopefully get into XP - I am tempted to take the 1GB memory from my Vista machine - but since I don't know what I am doing - I think I'll wait to get some feedback.
Any suggestions?
TIA
Wow - talk about a fast response!
Thanks guns1inger - I'll have to find my manual, I know its somewhere.
By the way, what physical damage might I have done? -
If you don't get anywhere with the jumpers, unplug the PC and remove the BIOS battery, wait about 3 or 4 minutes, then reinstall it. That should at least get you back to the default settings.
If you are getting RAM errors, replace the RAM. It's fairly inexpensive at present and you can't fix it anyway
. Some RAM has a lifetime guarantee. Kingston should. If yours does, get a RMA from the manufacturer and replace it. I would only buy RAM from one of the larger companies and only if it has a lifetime guarantee.
You can also try running a memory test program like Memtes86. http://www.memtest86.com/ Let it run at least an hour or two.
Usually you can only damage memory by adjusting the voltage improperly in BIOS. I doubt that's the problem. -
With your computer unplugged make sure RAM is correctly seated and locked in. Then it depends on your motherboard, some motherboards like Asus recovers and post in default setting. Findout what motherboard you have then go to its website and look at the manual how to set default. Newer MB don't use jumper some even have double bios. Your 1st task is to find out Name and model of your motherboard. Give us more info you have 1 stick 512 or 2 stick ..
Thanks for the replies
I removed the battery for a few minutes - put it back in - computer posted - then I set "Optimal Defaults" - saved and rebooted - seems fine
Thanks for the advice - now for the bad RAM problem - it's my understanding that it could be the motherboard - can I simply test this 512 RAM stick in my Vista machine - what settings do I need to be aware or will the BIOS pick up the new RAM and create auto settings - and/or is it safe to install the 1 GB RAM from my Vista machine into the MSI motherboard that I want to test ... simply put - are there compatibility issues here?
TIA -
easier to test in in the computer it's in. no worries about wrong type/speed.
try microsoft's tester - http://oca.microsoft.com/en/windiag.asp
or any other ram test that self boots into a dos environment.--
Thank goodness for more ram - old computer shines
By yoda313 in forum Off topicReplies: 14Last Post: 2nd Jun 2011, 18:03 -
Pc won't boot when new RAM installed
By r3n4ud in forum ComputerReplies: 13Last Post: 25th Sep 2010, 13:20 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 13:06 -
ffmpegx won't encode at all--Ram to Mp3
By redwillow in forum ffmpegX general discussionReplies: 1Last Post: 6th Aug 2009, 10:55 -
the type of RAM used by my computer
By bballnut in forum ComputerReplies: 2Last Post: 21st Jan 2009, 20:45
